DRCC Freezing
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by dhancock, Jun 18, 2012.
  1. ssinner2466
    ssinner2466 New Member
    2013 Prius v wagon
    ** UPDATE **
    I took the car to the dealership only to be told the following day that they couldn't find anything wrong with the vehicle and considering how windy it was, the problem was most likely caused from debris passing the sensor. They also advised not to use cruise control since the sensors only work when it is on. After what happened , I will no longer use cruise control. So guess what? The same thing happened today! I can't blame what happened on cruise control since I no longer use it and it wasn't windy (there goes THAT theory. I immediately went home and picked up my husband so he could be my witness. It did it again with him in the vehicle, with only the alarm sounding and seat belts retracting. Then it happened again with the alarm, seat belt AND the brakes! This time, there was a car behind me. Thankfully they were paying attention and weren't following too close. I definitely would have been rear ended. I took the car back to the dealership and gave them permission to keep my vehicle and drive it around ... we will see what happens. I will keep you all posted.
  2. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    Radar is active at all times (in order for PCS to work), not just when the cruise control is on. The only way to deactivate it is to use the PCS on/off button. Dealer doesn't know what they're talking about.
  3. rdgrimes
    rdgrimes Senior Member
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Its possible the radar gizmo in the front grill needs to be adjusted.
    But yes, turning PCS off should solve the problem.
  4. dhancock
    dhancock 2 Prius Family
    357
    40
    Hamburg, NY (Buffalo area)
    Freaking STUPID dealer!! :eek:
    Frankly, it ain't aiming - it is a malfunction in the electronics and all related assemblies should be replaced!
  5. Bill Norton
    Bill Norton Senior Member
    2,230
    746
    MONW, Ks.
    2019 Prius
    L Eco
    It is possible that there are Yahoos running around with Radar Jammers on all the time.
    That is a job for the FCC to capture them.
    Only driving around with a spectrum analyzer and an expensive antenna looking forward and recording data all the time will tell if this is what is upsetting your car's system.
    There have been cases of jerks with GPS Jammers. A few times a day an airport would report a degradation in the GPS signal. It was tracked down to one truck passing by the airport on the road close by.
  6. dhancock
    357
    40
    At least in my case, that (Yahoos with Radar Jammers) would not be the case. There was too much consistency among instances of the problem for that to be the cause.
    Why can't you accept that Toyota (or their vendors) is not perfect? Too many folks are drinking the Toyota cool-aid.
  7. Bill Norton
    2,230
    746
    MONW, Ks.
    2019 Prius
    L Eco
    No, I'm with you. It can be a very unsafe condition when this complicated system malfunctions.
    I hope you make Toyota get to the bottom of this.
    When I went shopping for my Gen3 I really wanted a level 5 with the ATP package but could not find one, at least in my price range. I was looking forward to hacking the LKA, Lane Keep Assist, so that I had a 2 axis autopilot in my car.
    Is it true that Toyota no longer offers the LKA?
    Was that because of serious problems?
  8. dhancock
    357
    40
    It is apparently still part of the ATP (Advanced Technology Package). It was the (useless) Parking Assist feature that was dropped in favor of the Heads Up Display. The Parking Assist was not worth all of the effort it took to "set it up".
    I've periodically used the LKA and likes how it works. The biggest complaint that I have is not so much the feature itself, but with the crappy condition of many of the road lines. When it looses a line it beeps when it captures the line again. On some roads (some states are worse than others) the constant beeping drives me crazy and I turn it off. I also don't like to use it when there may be ice on the road: the LKA "feedback" to the steering wheel feels a bit like the car is sliding. Don't need false signals 'then. Also the LKA has some problem capturing lines when the road is wet.
  9. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    I actually find myself using it periodically when I'm in the mood and just for the heck of it and it's MUCH faster when you skip the pre-support system. Just pull up as normal (side-mounted radar is active at all times, just like front radar for PCS), shift into reverse and hit the lower right hand button to make the green lines appear and pull into spot. No set up required. The only limiting factor is how fast you can go while reversing.
  10. ssinner2466
    2013 Prius v wagon
    There is a freeway expansion joint on the interchange/ramp where this has occurred. The dealership thinks "that" could be setting off the system with it being interpreted as a hazard. They actually suggested that I take an alternate route and to complain to CalTrans. I told them to take my vehicle and one that is similar, and to drive interchange. If it happens to both vehicles, then it is the joint. If it only happens to mine, then it's my system. I can't risk driving if my system is going to interpret every freeway joint or city grate as a potential hazard. As it stands, I never know when my car might slam on the brakes and it makes me uneasy just driving it.
  11. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Your dealer is pretty dumb. I'd find a different dealership and hope they're not as dumb as this one.
    Yes, that'd be the most appropriate control to determine which is the culprit.
  12. dhancock
    357
    40
    I haven't tried skipping pre-support. Maybe I'll give it a shot. BTW: Side sensors are NOT radar, they are sonar. Huge difference in component cost.
  13. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Yes, you're right on both counts. I had forgotten they're sonar and the flat radar-compatible front emblem alone is $900.
  14. Bill Norton
    2,230
    746
    MONW, Ks.
    2019 Prius
    L Eco
    What's the latest on comparative testing of two cars at your known problem areas?
    I would love to be able to do site testing with a recording spectrum analyzer, if I lived in the area....
    Are you saying that certain expansion joint always messes with the system?
    Are you saying passing semi trucks are always a problem, or just certain trucks or at certain locations?
    Could there be railroad communication antennas close by to the overpass? Other weird antennas in sight of the problem areas?
    There's a small possibility that something is putting out illegal interference. But then, any car with this sort of system would also freak out in those areas.
    I like trouble shooting!
    But you know you need to find a dealer that has some experience with the ATP systems.
    Did you talk to a regional rep? Toyota should at least point you to the dealer that knows the system.
    The one you are dealing with sounds like they just want you out the door.
    Good luck,
  15. dhancock
    357
    40
    You are mixing up two different people with two different problems. It would help if you would read the posts more carefully (as I was pretty clear in my posts [I am the OP for this thread)] about circumstances.
    The expansion joints issue was posted by another concerned Prius owner (ssinner2466). What is common to our problems is that dealers are totally incapable of dealing with ATP problems and that the factory is of NO HELP AT ALL!
    Regarding my (DRCC Freezing) problem:
    • Happened in different locations (NY, Ohio, Indiana) on Interstates
    • Only happened when hot
    • Only happened when passing the cab of a Interstate semi
    • Contacted factory so called "Customer Service" several times: All they would do is have the dealer call me (I had requested a meeting with Regional Rep.)
  16. Bill Norton
    2,230
    746
    MONW, Ks.
    2019 Prius
    L Eco
    Sorry, just trying to help a little.
    I wonder how common it is for ATP to go bonkers?
    Maybe I'm glad I did not spend the extra for that option....
    Good luck everyone with ATP problems. Keep us informed.
  17. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    Not common at all, as is the case with random failures. ATP can fail just like any other components so what you see here are isolated cases. The vast majority of us have defect-free ATP.
  18. dhancock
    357
    40
    And we keep on using the DRCC. Personally I love it (and miss it when I am driving our 07 Prius).
    But, these isolated cases do show how ill-prepared Toyota and the dealership network are for dealing with such problems.
  19. ssinner2466
    2013 Prius v wagon
    The first time it happened, I accepted the possibility that, due to the windy conditions, debris blew past the PCS sensor triggering it to activate. The next few times, it was evident something else was the culprit and took the car to the dealership. They have had my vehicle since Thursday June 20th.
    This is what has been accomplished:
    They haven't driven my car or a comparable vehicle over the expansion joint ( who knows why)
    I have been told to drive my car an alternate route
    I have been told to shut off the PCS
    They are still waiting for a "specialist" from Toyota
    I understand how the system works but to suggest turning on the PCS only on extended road trips makes no sense. Are you telling me that there are no overpasses on a long road trip? To suggest that I turn the PCS off and on only "when I need it" defeats the purpose of why it was installed or why I was charged for it. I will keep you posted but as you can see, progress has been slow.
  20. rdgrimes
    1,740
    448
    New Mexico, USA
    2018 Prius Prime
    Isn't the PCS supposed to respond to big chunks of metal in the road? Seriously, no system is perfect and the manual does clearly state this can be a problem. Shutting it off at those locations you know to be a problem isn't REALLY a big deal.
