Dreaded flat tire and I dont like it a bit :(
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Sanjath, Nov 24, 2012.
  1. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I've actually heard people say that. Way to often too! People get paid to clean this stuff up so why do I care.
  2. retired4999
    2,652
    627
    Eau Claire, Wi.
    I own 4 acres on a county road, this last spring when the snow melted I had 7 tires and rims in my ditch. Need less to say I was quite pleased! Not!
    People just do not care any more about their neighbors.
    Okinawa and F8L like this.
  3. Mendel Leisk
    42,343
    Around here you'll see dumster diver's ruminations spread around local green trails. Things like cables, small appliances, tv's, clothes, shoes, you name it. The sad thing, virtually all this stuff is readily recyclable. We have Returnit that takes bottles, tetrapacks, Styrofoam (all types), tvs, computer components, various small appliances. And for scrap metal and cables, stuff like old lawn mowers, barbeques, there's one outfit: Happy Stan's, that'll take it all.
    retired4999 likes this.
  4. jack520
    jack520 Member
    154
    40
    2014 Prius Plug-in
    Well, my wife wont drive out in the middle of nowhere without me. And, I am glad she would just call someone to fix it...life is too short to worry about flats.
  5. bisco
    52,849
    can't argue with that logic.(y)
  6. CarmelPrius
    CarmelPrius At 1 mile.
    49
    Maine
    When we got our 2012 PIP, we purchased a spare wheel (over $600) and keep it behind the passenger's seat. A PITA, but better than being stranded somewhere. And, we got AAA to have someone change it when necessary. I'll not buy another PIP due primarily to this no spare issue. It's totally nuts. We have 4 summer tires and 4 winter tires, so use one of these on the spare wheel.
  7. bisco
    52,849
    agreed. but i will buy another, and keep a mini spare in the hatch like i do now. but i won't like it.:mad:
    lensovet likes this.
  8. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    Are the people upset about no-spare tires constantly blowing them out or something? The only flat I have had in over a decade was on my Leaf. I hit a giant pothole and it popped the almost new crappy ecopia tires. I drove super slow a block over and had the tire store put on a new tire. No matter where I am in town, I am always close to a tire store. And with AAA, it is hard to imagine you are more than 100 miles from a tire store. I don't even know or care if my Leaf has a spare.
  9. bisco
    52,849
    i haven't had a flat in 20 years or so. i still like the security of a spare when i'm out of range of my binky. i don't want to hope i get a cell connection, wait for triple a or toyotacare, get a tow to the nearest idiot, yadda, yadda, yadda. i want to jack 'er up, change 'er out, and be off. it's cheap insurance if you have the space. mine is on the deck, no prolemo 99.9% of the time.
    DadofHedgehog and lensovet like this.
  10. bisco
    52,849
    hycam still has a full spare and a pretty decent trunk. not bad for 40+ mpg. if they ever come out with a plug in and no spare, i'll do the same thing. i'm not driving through georgia without a spare.:cool:
  11. Sanjath
    Sanjath Member
    107
    23
    SF Bay Area
    Looks like it has been more than 2 years since I started this thread, since then I have bought a spare (thanks to one of the posters here), I keep it in garage, I never had to use it. Yay! :) Most of the times the car is in the commuting roads of 880-237-101 in bay area. I took the car to LA once, carried the spare, but everything went fine.
    I feel buying the spare is a good decision as it gives you a mental peace. I have also bought the tire warranty from 'American Tires'. So, if I just rely on the toyota care, I may not be able to use the warranty as they tow only to nearest dealership.
    Anyway, I think I may had a bad tire to my luck. After $175 for tire change, $60 for warranty and $40 for spare, it has been happy ride so far.
    mmmodem likes this.
  12. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    I discovered I picked up a screw when I found the car sitting on a flat tire in the driveway so now I am reconsidering my stand on "no spare tire".
  13. bisco
    52,849
    you have one though.
  14. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    I think we bought the car at nearly the same time. How many miles you got on her now? Those are my highways, add on 80 and occasionally 580 when 880 gets stuck. I'm looking at 61k miles in front of me. My tires still look pretty good. Low tire pressure came on a year ago. I risked limping it along and I had it patched at America's Tires for free.
    Sanjath likes this.
  15. se-riously
    se-riously Active Member
    263
    114
    SF Bay Area
    2014 Prius Plug-in
    Got a low tire pressure indication on my dash on Saturday. Checked the tires and the right rear tire picked up a screw. Measured 27 psi. So I decided to try out my tire repair kit that I keep in the trunk cubby, which consists of:
    - tire plug kit
    - foot pump (I don't use a 12v powered one for fear of blowing the circuit. Those that draw under 10A are slow anyway.)
    - two pliers (one to pull out the nail/screw, and the other to cut the tire plug)
    I was at home and I have jackstands, a much better jack, tools, etc., but wanted to simulate a repair job on the road. Using the factory scissor jack, which comes neatly packaged underneath the driver's seat, I proceeded to remove the tire, plug it, and reinstall. Bottom line is that it worked like a charm. Things I already knew, from past experience, is that it's a lot easier to ream the puncture and install the plug when there is air in the tire and to jack the vehicle just barely enough to remove the tire (no higher). Lessons I learned were:
    1) Store some latex gloves to avoid dirty hands.
    2) The foot pump's pressure gauge overestimated by 7 psi (40 psi displayed was actually 33 psi).
    3) The scissor jack is a bit flimsy, but it does the job. Best if you have any passengers to have them exit the vehicle and stand off the shoulder at least 100-feet in front of the car. You should do this anyway regardless of the type of emergency.
    Robert Holt, Mendel Leisk and bisco like this.
  16. Mendel Leisk
    42,343
    Another good item to have is a pair of lightweight wheel chocks, at the tire diagonally across from the flat. Plus a small square of wood/plywood, in case you're jack is sitting on dirt or gravel.
    I had a sim. situation, except had the temp spare to fall back on. The scissor jack worked (but it's STILL a POS), plug-repaired in out of the cold at home, and reinflated the reapired tire with a bicycle pump. ;)
  17. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    I don't understand the fear of getting a flat. I've had probably a dozen in my 15 years of driving. Heck, I've had a stalled truck in the dead of winter up a logging road, and jogged 8 miles to the nearest town at 1am while it's snowing, wearing just a tee-shirt and jeans. No big deal. My point is that a flat is much less perilous than many people imagine. Heck, I'd give anyone a ride if they flagged me down (taxis do this too ;) ).
    Can anyone share a story of where the inability to continue on with a spare resulted in personal injury or great financial loss?
    I'm not too thrilled about the goo that comes with the Prius. I've had 100% success with plug kits, so I think I'll give the goo to my dad to use in tractor tires and just keep a plug kit in the car. I can't imagine why Toyota would choose goo over a plug kit, considering plugs are
    The only time I've had a flat that couldn't be mended with a plug is when I rolled the '69 Beetle and grass/dirt lodged into the bead. A spare came in handy that time, especially since that was before regular folk had cell phones.
    Now I'm thinking about removing the spare from the Camry and Acura. I don't roll vehicles anymore, so I can't imagine needing a whole replacement wheel.
  18. bisco
    52,849
    try it with 8 feet of snow on the ground, on a 2 lane road that's only 1 1/2 lanes wide at 9 degrees.;)
    Redpoint5 likes this.
  19. retired4999
    2,652
    627
    Eau Claire, Wi.
    Stay warm my friend!:)
  20. bisco
    52,849
    no prolemo, arrived in orlando today, went for a walk, a swim, and dinner al fresco. 63 at 10 pm.(y)
