Dreaded flat tire and I dont like it a bit :(
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Sanjath, Nov 24, 2012.
  1. se-riously
    se-riously Active Member
    263
    114
    SF Bay Area
    2014 Prius Plug-in
    Goo, if it works, doesn't require use of the jack, strength to remove the lug nuts, etc. That's about the only benefit. All of the minuses are well covered already.
  2. frodoz737
    frodoz737 Top Wrench
    4,803
    2,560
    33
    I can't believe this thread is still going.
    HaroldW likes this.
  3. retired4999
    2,652
    627
    Eau Claire, Wi.
    look out! Your getting closer and closer to me every year.:)
  4. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    This guy here is asking everyone to boycott Cadillac because it doesn't come with a spare. Idiot Shocked Spare Tires Aren't Standard Anymore: #BoycottCadillac
    I remember I took back my PiP deposit because of the spare. Then when I saw that just about every plug in has no spare either, I realize that it is the sign of times and I have to get with it.
    It's just like BMW only sells turbo engines, the cigarette lighter is no longer standard, you can't see the hood of your car anymore from the driver's seat. I wouldn't be surprised if the Gen 4 Prius doesn't have a spare either.
  5. Mendel Leisk
    42,343
    There's no reason to negate the temp spare on the next gen regular Prius. If they were to that'd be deal breaker for me.
  6. bisco
    52,848
    you can't go home again.
  7. bisco
    52,848
    a lot of aaron rodgers shirts around here.(y)
  8. lensovet
    2,615
    496
    Burlington, NJ
    sure there is. takes up space, adds weight. no electric car has one – not even the Model S.
  9. frodoz737
    4,803
    2,560
    33
    Tells us how that works for you next time you get a flat some night in Oakland waiting 1 1/2 to 2 hours for a wrecker contracted by Toyota at a lower rate to tow you to a closed Dealership.
  10. fuzzy1
    10,706
    That isn't the problem of the beancounters who set the fuel economy target for the next design.
    I'm not going to be happy when the spare tire is no longer included, but that is the way the market is going.
  11. Mendel Leisk
    42,343
    Unless customers freeze them out.
    Yeah, I know...
  12. frodoz737
    4,803
    2,560
    33
    Next car I try to buy without a spare will get one and a means to use it before I pay. Bean counters, economists and lazy people aside, I will never leave home without one or jumper cables.
    #352 frodoz737, Feb 22, 2015
  13. bisco
    52,848
    it's not horrible having it sit on the hatch deck, but yes, it would be nice if they made room for it. but i cannot make a car buying decision based on that.
  14. Redpoint5
    Redpoint5 Senior Member
    1,026
    509
    Portland, OR
    Why would I wait so long for lazy incompetent people to charge too much for a repair when I could plug a tire in 10 min and be rolling again?
    After reading this thread and thinking of probabilities and opportunity costs, I purchased plug kits for all of my vehicles and will be removing the spare from the vehicles that have them. At least the last 4 flats I've had were easily repaired by plugging.
    drash likes this.
  15. hieronymous
    hieronymous Member
    154
    92
    Auckland, New Zealand
    2013 Prius Plug-in
    Aussie Leafs have one - ADR (Australian Design Rules) require it.
  16. frodoz737
    4,803
    2,560
    33
    Exactly, why wait...and 10 minute chock to chock repair roadside (when possible)...BS.
    Without question I'll be on the road long before you "every-time" with a spare. If I'm driving, I have somewhere to be. I take care of repair (or replacement) later after proper eval and with proper tooling. But then again what do I know...I'm just some lowly mechanic. :whistle:
    To repeat, I can't believe this thread is still going.
    #356 frodoz737, Feb 23, 2015
  17. Robert Holt
    Robert Holt Senior Member
    1,313
    890
    The blowout last summer with our Prius was a 2-inch gash on the shoulder of the tire. Truck had a piece of sidewall about 1-inch diameter blow out, so both those were non-pluggable. I carry plugs pumps and goo and have used them successfully for other flats, but like having the spare also for the failures they cannot fix.
    Aside: new Michelins from Costco come with roadside service guarantee from Michelin. Have those on Tundra and Prius now but have not had to use it yet.
  18. Sanjath
    Sanjath Member
    107
    23
    SF Bay Area
    Wow... you got 60k+ already, I thought I was really adding more miles compared to my previous cars... :)
    Anyway, I have put close to 36k now. I did go ahead and bought the toyota extended service package that extends it to 40k miles, I know you suggested that it is not worth it, but decided to just go for it make it easier on myself. Recently, my work is on red wood city, so carpool is used only for bridge access, beyond that it is of little help, but still $2.50 a day is good savings, on the plus side, there are chargers at work, once I get an account, I can put more EV miles.
    mmmodem likes this.
  19. inferno
    inferno Senior Member
    1,072
    405
    In a situation where I have a blown out tire on the highway I wouldn't want to jack it up. It'd be too risky especially with family in the car. Unfortunately I think onStar or phoning someone is the best solution after safely getting out of the car and out of the road somehow. It's just not safe. And to fix a flat with a donut (what maybe 30 minutes the quickest in a regular Prius with a flag?) - then drive with the donut that can only go a max of 30 mph on a 65 mph road...I don't know.
    What I do fear is have a flat with no cell coverage on a quiet road. Then what is the option? And remember donuts have to have air put into them...
    There's no real good solution unless there a secondary bubble tire that comes up within the rim for just in cases...
  20. Mendel Leisk
    42,343
    ^ Owners Manual says 50 mph max, for the temp spare. And I'd suspect that's very conservative. Stay in the right lane, use flashers as needed.
    lensovet likes this.
