Dreaded flat tire and I dont like it a bit :(
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Sanjath, Nov 24, 2012.
  1. Sanjath
    Sanjath Member
    107
    23
    SF Bay Area
    One question regarding TPMS, when I had the flat tire, TPMS icon showed up on the screen but no details on which tire it sensed it. How do I get the details on which tire? My previous car used to show that information on which tire it is. The you tube video from toyota (2011) says you should check all tires if the light comes on. Is that same with 2012? Is it any better with advanced model?
  2. John H
    John H Senior Member
    2,208
    558
    If the shop is closed I can have it taken to one that is open. Discount Tire will refund the costs of a replacement tire if I have to get it replaced by someone else. If it is at night, I would probably just have it towed to Discount Tire and take a taxi home.
  3. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    Yeah, the system is not tire-specific, so if it senses that one tire is low, you may need to check them all with a tire guage if you have a slow leak, where it isn't obvious, as in your case. Can't answer about the Advanced, but my gut says it will be the same. I think it senses if a tire loses approximately 5psi.
    Glad to hear your TPMS sensor doesn't need replacement. That's one reason I went for a donut spare, so as to avoid even using the sealant.
    With regard to towing services, Lexus (so I assume Toyota) used to contract with AAA in So. California. But I heard a couple of years ago from someone familiar with AAA operations that they no longer held that contract. If any roadside service is going to take longer than about 20 minutes to respond, I would rather have a spare to put on, provided I can do it safely, and be on my way.
  4. Mendel Leisk
    42,343
    AFAIK, the TPMS will only tell you there is low pressure, but not which tire(s). Keep a pressure gauge in the glove box?
  5. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Get out of your car, place you fingers on the tread of each tire, then press mid sidewall with your thumb. You should be able to feel the difference in a tire that is 5 psi low.
  6. lensovet
    2,615
    496
    Burlington, NJ
    TPMS on base model doesn't show which tire is the problem. The advanced model has a screen on the display audio system that indicates which tire is the problem.
    There's one thing I find completely unacceptable in this whole situation, which is that the sealant that Toyota provides will require TPMS sensor replacement. That's just crazy. Especially when there are slimes you can buy online for just $10-15 that claim that they will not affect the sensors.
    rogerv likes this.
  7. lensovet
    2,615
    496
    Burlington, NJ
    As far as what's covered under warranty or not, my point was that due to the huge inconvenience caused, they SHOULD replace it because of the time and money you wasted due to their incompetence. If they had immediately sent the right truck and noted how many passengers are in the vehicle, OP would have saved at least an hour of his time.
  8. Sanjath
    Sanjath Member
    107
    23
    SF Bay Area
    LOL :), thats so old school !!
  9. Sanjath
    Sanjath Member
    107
    23
    SF Bay Area
    BTW, the TPMS monitor was OK. So, service adviser's first talk may have been cautionary or ...
    Service adviser told me that I have used up all the sealant, so I should consider buying a replacement. I asked for the price, I was told it is $160!! Holy cow! I thought it is not worth, if the tire change itself cost me that much.
    I did some google search, looks like the one that is available at O'reilley's is $20. I couldn't find price for prius specific one. But, I found this other thread where Nissan Leaf owner complaining about Nissan charging $200 for the same thing, so we are not alone :) Here's Why to Avoid Puncturing a Nissan LEAF Tire | PluginCars.com
    Well, looks like they need to do something on tire technology for the no-spare thing to work. I just dont think at this time it is a good situation :(
  10. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Yeah, kinda like looking out the windows occasionally when using a GPS to navigate.:D
    A year or two ago some people using their GPS to navigate got stuck far out in isolated wild country and died. A local Sheriff was quoted as saying "When you are using your GPS to navigate it's a good idea to occasionally look out the window."
    Sanjath likes this.
  11. lensovet
    2,615
    496
    Burlington, NJ
    No need for a Prius-specific sealant, it's not like there's something special about it. Check this one out for example, just $10 and tons of good reviews: Slime 10011 Tubeless Automotive Tire Sealant - 16 oz. : Amazon.com : Automotive
  12. CharlesH
    2,798
    1,166
    Roseville, CA
    That tire display disappeared somewhere on the way to the production model. As far as I know, no Advanced owner has been able to find it.
  13. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Another option is to replace the standard tires with run flats if you don't want to carry a plug kit. No one selling subscriptions to roadside service provides it. They all subcontract so the speed & quality of the service are going to vary. If you are going to spend the money & the space on a spare tire why not get some use out of it by going with a matching wheel & tire? In the old days a tire rotation included the spare.
    lensovet likes this.
  14. fuzzy1
    10,706
    No, it doesn't have to be the same diameter. That is one of the reasons it is best mounted on the rear, not in a steering position. The 135/80R16 temporary spare in my non-PiP should be about one inch smaller diameter than the 195/65R16 main tires.
    Think also about travels in areas with no cell phone reception. This is not an issue in some regions of the country. But I tend to travel in regions where the cell coverage maps have plenty of white space.
    Well, this was disclosed as a feature of the car, before you purchased it. Wasn't it? Toyota is not the first to go this route.
  15. lensovet
    2,615
    496
    Burlington, NJ
    Wait really? That's a bummer.
  16. SJ PiP
    SJ PiP Member
    190
    35
    tire rack is selling cheap 15" steel wheels ($56). Tires and Wheels Package | Tire Rack
    any issues using a steelie as a spare (with a lower priced tire, would be ~$150... worth peace of mind in my book)? i guess the TPMS would not work but this wouldn't be a permanent fix anyway.
  17. lensovet
    2,615
    496
    Burlington, NJ
    TPMS should still work on the remaining 3 tires.
    Also if you really wanted to, you could install TPMS on the spare as well…
  18. Sanjath
    Sanjath Member
    107
    23
    SF Bay Area
    I guess TPMS not working is OK as it should be a temp solution.
    That seems like a good one, can any of the resident experts chime in on any downside? Thanks.
  19. rogerv
    1,639
    317
    We all got along fine for many years without TPMS. It was brought about by the Ford Explorer/Firestone Tire debacle several years ago. SUVs were rolling over when underinflated tires blew, so our government came to the rescue, giving us a system to tell us when our tires lose air, instead of us being responsible car owners, keeping track of something as routine as that ourselves.:rolleyes:
