Dreaded P0A80 Code - Car Running / Charging Good.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by PriuSocal, Jan 25, 2026.
  1. PriuSocal
    PriuSocal Member
    377
    62
    SoCal
    So after getting this car last week, I was driving today and coming to a light the “Check Hybrid System” came on along with the TOD, VSA and CEL lights. I have an Autel AP200 dongle specifically for Toyota and when looking up the HV battery / block voltage values, all 14 were very similar hovering around 16 and 17v. It also had a 0 under “times battery very low” or “very high”.
    I am new to reading HV battery readings and as mentioned above, bought an AP200 (recommended by another user to buy) and have Dr. Prius app installed on my ipad. I have looked up a few other threads on here about this very common code but symptoms all appear to fluctuate. The weird thing is the car is running good, charging and holding a charge in what appears to be normal fashion. I thought to check the hybrid fan 1st but I am in unfamiliar territory with the HV batteries and will need to rely on other posts and youtube videos for now.
    A little on the car:
    - 2015
    - 260k
    - 12v Battery Replaced right before i bought it
    - HV battery original or replacement or service unknown
    - History showed P0300,P0302, P0303 and P0304 codes when I ran a check but CEL off and monitors incomplete (most likely due to the battery replacement).
    - Car had a Multi Point Inspection at Toyota prior to sale and NO mention of failing or HV battery or current issues/codes, only random things like brakes and struts etc.
    - The History codes are now gone and only P0A80 is now current code.
    Lastly, I apparently saved a PDF copy of the live data for the HV battery on the Autel App but cannot figure out how to access the file as it is not under my downloads or anywhere when searching and the app wont show a saved pdf file folder.
    I appreciate all the help or direction.
  2. PriusCamper
    PriusCamper Senior Member
    13,422
    5,420
    Pacific Northwest, USA
    Used car dealers have a reputation for selling vehicles that they can barely keep that error code from coming back long enough to sell it...
    I suspect you have a weak cell in your pack that runs ok until there's a high amp load going through it during hard acceleration or hard braking. To confirm you can monitor "volt diff" numbers via Dr. Prius app while driving and you'll notice that number going up during high amp loads. As long as battery temps don't go too far above 120ish you can keep driving and clear code as you go.
    As for what to do next, I'd suggest studying Lemon laws in your state and holding the seller's feet to the fire for a rebuilt or brand new replacement battery pack.
    You could also buy a used replacement module for $40 and put it in and if you're luck get a year out of it... Or you could buy some gear and do a thorough rebuild yourself.
    PriuSocal likes this.
  3. Brian1954
    Brian1954 Senior Member
    2,667
    1,066
    South Central PA, USA
    Look at the freeze frame data for the P0A80 code. That data will show the voltages of the 14 battery blocks when the code was triggered. One of those 14 battery blocks will show a voltage lower than the other 13 blocks. Then, you need to decide if you want to replace battery modules to fix the problem or replace the complete hybrid battery.
  4. PriuSocal
    PriuSocal Member
    377
    62
    SoCal
    I bought it from a private party. So, usually those sales are AS-IS sales here in CA unless stated otherwise. I have been reviewing some videos and looks like the testing for the HV batteries is extensive using apps like dr. prius etc.
  5. PriuSocal
    PriuSocal Member
    377
    62
    SoCal
    I will do that next and report
  6. PriusCamper
    13,422
    5,420
    The Dr. Prius app testing won't help find the bad cell/module that needs to be replaced. But if you want to pull the pack for testing we can walk you through that.
    More to the point, what's your budget for resolving this? Because upgrading to brand new sodium-ion would be a significant upgrade to the performance of your car for years to come. Way more fun to drive than even a brand new OEM pack.
  7. PriuSocal
    PriuSocal Member
    377
    62
    SoCal
    At this point I dont have a significant budget towards battery replacement. If determined that it needs a new battery, I would need to hold off on it for a few months if that.
    I recall when my transmission went out on my gen 2, after replacing it and fixing it. The P0A80 came on as well but I was not having issues with the battery. After resetting codes, it did not come back on and it's been 5-6k miles since. So this is the reason why I dont jump directly to assuming my battery is bad until I do a bit more research.
    Also, never used the Dr. Prius app but can I use my AP200 as a VCI for the app or do I need something else to connect it from my ipad to car.
    #7 PriuSocal, Jan 25, 2026
  8. rjparker
    rjparker Tu Humilde Sirviente
    11,038
    6,920
    Texas Hill Country
    A multipoint inspection is almost always done by the oil change guys whose marching orders are to sell brakes and struts.
    The Dr Prius guys will tell you their apps testing won't be accurate with a current P0A80 and clearing it does not solve the problem. They do sell their sodium cells for almost the cost of new oem.
    #8 rjparker, Jan 25, 2026
  9. PriuSocal
    PriuSocal Member
    377
    62
    SoCal
    I see, they did report to replace the 12v battery but not HV. I guess the MPI means nothing when it comes to the serious codes then.
  10. rjparker
    11,038
    6,920
    Texas Hill Country
    A battery test is quick and does not require a scanner.
    Even if you paid for a PPI (pre-purchase inspection) which would include a scan, a P0A80 is replace hv battery for them.
  11. PriuSocal
    PriuSocal Member
    377
    62
    SoCal
    Thats def true, they dont troubleshoot they just replace. Well I look forward to to taking all the help you can to help me figure this one out as unlike most mechanical issues, this is uncharted territory for me. Do you suggest i look into the battery fan possibly being dirty? I ask since some say it can cause the p0A80 code and others say it wont,.
  12. PriusCamper
    13,422
    5,420
    I'd love to know if your Autel works with other apps, like Dr. Prius... If not, the OBD2 readers that work only cost like $20: http://www.ebay.com/itm/265484403768
    As long as you can clear codes while driving and hybrid battery temp doesn't get too hot, you can keep using your car while we walk you through getting ready to replace a module. Are you up for doing work like that?
  13. PriuSocal
    PriuSocal Member
    377
    62
    SoCal
    I went ahead and took the back apart to get to the Hybrid battery fan and wasnt too dirty, as if it had ben cleaned before. I also noticed the 12v battery terminals were loose and not properly seated and a new 12v Duracell battery as well as the vent tube was not connected. I seated them and tightened them as well as reinstalled the vent tube. Also, found 2 loose bolts loose and 2 missing 10mm nuts.
    Nothing out of the ordinary but did not go into taking the battery apart, I did remove the orange safety plug and reinstalled it for safe sake and all was well. Came back, started the car and erased the code and drove the car around the block, felt a bit stronger but could just be a placebo effect from having taken stuff apart and reinstalled. I also have the Autel Report which I will attach below of when the P0A80 code came on.
    One is the freeze frame data and the other the live data
    PriusCamper likes this.
  14. PriuSocal
    PriuSocal Member
    377
    62
    SoCal
    1. My 1st observations of the report are that the voltages range from 12.71 V (Block 08) to 14.47 V (Block 07). This is a difference of about 1.76 V.
    2. Block 08 (12.71 V) and Block 05 (13.23 V) are particularly low compared to the others
    3. A quick search pointed out since the Delta SOC is 6, could cause damage to the overall battery. I have heard of “balancing” the batteries, is that a task one can perform with the battery on the car? If not, can the process still be done as a DIY or only by a shop with specific equipment and what type of cost is one looking at for such “maintanance”?
    I hope im not getting ahead of myself.
  15. indel
    indel Member
    283
    89
    Northwest Indiana
  16. ASRDogman
    ASRDogman Senior Member
    8,052
    4,083
    You can get the Prolong charger/discharger. You just install the wiring harness then you only have to
    plug in each piece when called for.
    If you run the 3 charge and 4 discharge cycles and let the last charge cycle go for an extra 6 hours
    or so after it has stabilized, that will "balance" the pack.
    That is the SAFEST way to do it.
    If there is any life left in the pack, it will bring it back to life, to "Prolong" the it's life.
    Eventually, you will have to replace it.
  17. PriuSocal
    PriuSocal Member
    377
    62
    SoCal
    Wow, So I assume the battery has to come out for this “prolong” device to be hooked up? I will have to look into one of those. Are they pricey?
  18. indel
    indel Member
    283
    89
    Northwest Indiana
    Working with electricity is inherently dangerous. I don't mean to sway you away from working on your car, but be mindful of the risks and use PPE. The battery is upwards of 200 volts and can cause serious damage or death. If you search in my post history, you will find one with all the tools I bought to work on this.
    That being said, yes, the battery needs to come out. The charger shown in that video is probably the most popular and it currently runs about $250 USD. You will need some stackable banana plugs with alligator clips. Buy them in 14AWG.
    Needless to say, while it's entertaining to watch the guy automate his process with custom code and electronics, not everyone is capable of those things. Yes it's more work and will probably take 2-3 weeks, but it's definitely doable.
  19. ASRDogman
    8,052
    4,083
    No, you just have to remove the top cover to get access to the block wiring.
    About $750? Not certain. You'll have to check their we page.
    Hybrid Automotive – Extending the Life of Your Hybrid
  20. rjparker
    11,038
    6,920
    Texas Hill Country
    Used mix and match is the best short term fix but still may only get you a year or two.
    Prolong "chargers" may raise a non functional battery from the dead (eg won't spin the engine to start it) "prolonging" its use but a battery used every day or two is just as effective.
    Many end up selling their Prolong chargers for half price.
    This is what it takes to get a couple of years (remembering new oem gets 10-15 years trouble free):
    The Hybrid Guy NiMh Battery Rebuild
    Someone selling one with matched replacement modules might charge $1600-$2400 and you still are lucky to get a couple of years before doing it again.
    #20 rjparker, Jan 26, 2026
