Drill hole in tube?
Discussion in 'Fred's House of Pancakes' started by cyberpriusII, Aug 4, 2024.
  1. cyberpriusII
    cyberpriusII Maybe it was the roses
    1,157
    1,850
    Hyampom
    Need to drill 1/4" inch (??) hole into small chrome tube --- only through one side.
    Saw lots of online suggestions but what if I took a worm gear hose clamp and fastened around tube and then slip the bit between the "slit" in the clamp to hold bit on place as I start to drill?
    kris
    bwilson4web likes this.
  2. PriusCamper
    PriusCamper Senior Member
    13,403
    5,412
    Pacific Northwest, USA
    52,774
    that should work
    PriusCamper likes this.
  4. PriusCamper
    13,403
    5,412
    Unlike your Potassium Battery pack... Lol
  5. bisco
    52,774
    hey, don't discount future technology, the future is now
  6. cyberpriusII
    1,157
    1,850
    Hyampom
    Thin wall tube. Not "fragile" but no centerpunch
    kris
  7. Prius Maximus
    Prius Maximus Senior Member
    956
    811
    Northeastern IL
    That tube will bounce around like a mexican jumping bean on a pogo stick. What's inside diameter? Can you get a dowel rod to match and put inside so you can clamp it down without distorting the tube? No matter what, I still think a punch to start the hole is the best idea. Use a drill press, not a handheld drill, and anchor the tube so it can't bounce around.
    vvillovv likes this.
  8. ChapmanF
    18,956
    Must go try this.
  9. PriusCamper
    13,403
    5,412
    That kind of thinking is so yesterday and outdated!
  10. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,559
    2,599
    Taylors, SC
    I'd use a Dremel with a burr tip to grind a depression in the place where you want to drill the hole and drill it out with a clean cutting step bit like a Unibit.
    A Unibit will cut a clean round hole in thin metal,
    #10 Georgina Rudkus, Aug 5, 2024
    Trollbait and PriusCamper like this.
  11. Leadfoot J. McCoalroller
    8,269
    7,774
    Pennsylvania
    2018 Prius c
    why not flatten the hose clamp on a tabletop, make a punch and drill a hole through the clamp, then put the clamp around the tube and use it as a guide?
    ...you still want to anchor the tube, and I like the dowel idea.
    #11 Leadfoot J. McCoalroller, Aug 5, 2024
    Trollbait likes this.
  12. bwilson4web
    16,512
    A small, pilot hole will set the direction and location. Than larger bits as needed to finish.
    Second alternative, now you can justify that drill press and clamps. <GRINS>
  13. Trollbait
    12,806
    Whatever the exact method, starting with the smallest bit and working up will make the job easier.
  14. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,094
    Columbia, SC
    Use a nail. Larger is better. The point will work better anyway. Just be careful.
    Depending on wall thickness, even a good sized wood screw or drywall screw can be a good substitute. As mentioned, be careful, they're pointy!
    Chrome plated tubes can be slippery for a bit to grab, so DO NOT let your fingers or hands be near the bit when applying pressure. Safety first! I've seen too many knuckleheads put drill bits and driver bits into fingers and hands.
  15. ETC(SS)
    7,497
    If it's a tube, doesn't it already have two holes?
  16. vvillovv
    vvillovv Senior Member
    4,336
    1,518
    NY
    Now you've done gone and done it. I'm stumped ... How did you drill a hole in a small chrome plated tube?
  17. bisco
    52,774
    you need a small piece of angle iron type material. drill through from the inside, then place it over the tube and use the pilot hole
  18. Leadfoot J. McCoalroller
    8,269
    7,774
    Pennsylvania
    2018 Prius c
    I forgot you spoke plumberese.
  19. bisco
    52,774
    would this work? start at 30 seconds
    watch
  20. PriusCamper
    13,403
    5,412
    This thread kinda makes me wonder how many PriusChatters it takes to screw in a light bulb...
    Brian1954 likes this.
