Drive-in theatre Prius Lights
Discussion in 'Gen 5 Prius Main Forum' started by Tekbar7522, Jun 14, 2026.
  1. fuzzy1
    10,707
    Maybe he wanted to listen to the movie, not make out with a companion.
    The old-era theater-provided wired speakers that viewers hung on their side window, are long gone. His theater likely provides the audio via a standard radio channel.
    I thought my old Prius in DRL mode (or is it the Subaru??) would start up with DRLs off, and not turn them on until either shifting out of Park or releasing parking brake. But once turned on, the DRLs stayed on until ignition shutoff. That mode would solve his drive-in theater problem while still meeting Canada's DRL requirement while moving, IF Toyota chose to include it on Canadian models too.
    I think it is has nothing to do with the Arctic Circle, but instead because they are smarter and more safety conscious than the U.S. Or at least less hostile to gum'nt regulation.
  2. Trollbait
    12,829
    GM wants that government regulation; it would save them money on light switches. The NHTSA's response to the lobbying was that there isn't enough evidence that mandatory DRLs would help prevent accidents.
    Latitude could be a factor. DRLs have more impact during the dusk lighting of sun rise and set when there are plenty of shadows, yet enough light people may not have headlights on. Those periods are longer the further from the equator you are.
  3. fuzzy1
    10,707
    Sounds like some GM cheapskate bean counters were pushing back on the financial disadvantage of voluntarily putting in those light switches when some competitors might not.
    Numerous lower-latitude areas here are afflicted by considerable seasonal severe- and full-overcast skies that have similar visibility issues.
    And I still see a fair number of vehicles driving beyond dusk in full night darkness, with just the front DRLs (reduced power headlight type) and no side or tail lights, though the proliferation of automatic lights does seem to have taken a big bite out of this problem. The newer Canadian requirement for automatic taillights too, would do an even better job of remedying this problem.
    DRLs implemented as separate LED lamps without a headlight pattern, seem to be less of a problem.
  4. Trollbait
    12,829
    Their cars already had DRLs, so I think it was more about going to a single dash switch for Canada and the US vs having provide one with an off position in the US. Reduction in the parts inventory.
    As it was, the US switch had a spring that popped it out of off to auto, so you'd have to switch to off whenever the car was turned on if that was your preference. Owners were defeating that.
    I was supposing on why NHTSA is saying why there isn't evidence showing DRLs help.
  5. fuzzy1
    10,707
    Is there any legal or other good reason to not just adopt the Canada-market switch in the U.S. too? Besides possible push-back from customers or bean counters?
  6. Trollbait
    12,829
    My guess is the customer push back is a big par. Which could lead to lost sales to those still offering an off on their switch.
  7. Gokhan
    Gokhan Senior Member
    6,714
    2,672
    Paramount CA
    I have never been to one. I don’t know how they work. I thought they were a 1950s thing, but there is actually one a few blocks from my home.
    There is no off position on the light switch, only an auto position. So I believe the lights will turn on immediately when you turn on the car. My US version also adds a DRL-off position.
  8. Tekbar7522
    Tekbar7522 New Member
    2026 Prius Plug-in
    thanks for all the tips Hammersmith and others!
    I was able to swap out the stalk with one I got on ebay. Like you mentioned it was a bit difficult to turn the screw with the Allan key through the small "window". There wasn't enough space for any wrench, or screwdriver, but doing it with the Allan key wasn't too bad.
    Then removing the stalk after removing the 2 screws was hard, until I figured out there was a clip holding it back on the side closest to the steering wheel, I had to pull back a bit. I should have taken pictures for this forum, but didn't think of that until I put it all back together.
    All done without having to take the steering wheel off.
    Now for the functionality, when I switch DRL off, it turns off the bright red light in the back, and the daytime running lights are off. But the lights that are decorative where the headlights are, remain on. I don't think those can be turned off completely, even with turning the parking brake on before starting the car.
    Oh well, at least the bright red light at the back and the DRL's are off now. I'll come up with some sort of cover I'll make with maybe a magnet and piece of tarp that I can cover when I go to the drive-in. I think overall it was a success swapping it out, but will see when I go to the drive-in next time.
    Thanks again for all the help and comments on here. Really appreciate it!
    Trollbait and mva like this.
  9. Hammersmith
    Hammersmith Senior Member
    2,487
    2,546
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    Sorry we weren't able to quite get you there.
    Regarding the lights that won't turn off, are they part of the main headlight array or are they the bottom lights down near the ground? If they're part of the main headlight array, are they claw shaped, round, or a bar? Finally, are they white or amber?
    If we can figure out exactly which lights won't shut off(and their proper Toyota name), maybe we can find a workaround.
  10. Mendel Leisk
    42,347
    The drive-in transmits the soundtrack of the movie via an FM frequency? Leave the car off, bring along a portable radio? Appreciate it's not the same sound quality, but it'll make it seem more like the fifties drive-in, when you lifted a speaker of a post, hooked it on your window.
    Gokhan likes this.
  11. Gokhan
    6,714
    2,672
    Paramount CA
    Why not the same sound quality?? It should be better sound quality.
  12. Tekbar7522
    2026 Prius Plug-in
    Actually I stand corrected. Sorry for the confusion. When I tested last time, maybe I didn't set the parking brake before turning on the car. This time I waited until night, turned off DRL, set the parking brake, started the car, and the lights are all off outside! Yay, thanks so much
    fuzzy1, mva and Hammersmith like this.
  13. Tekbar7522
    2026 Prius Plug-in
    yea, I thought of that as an option, but its nice to use the car speakers, and if it is hot, use AC, and when it is closer to winter and drive-in is still open, will be good to use some heat. But thanks for the suggestion none the less. :)
  14. mva
    mva Active Member
    177
    105
    B.C. Canada
    2024 Prius Prime
    SE
    This is great information, that it worked for you. Would you confirm which part number you used? Was it 84329-33080, as hammersmith recommended?
    I also want to do this modification but for other reasons such as stealthy car camping and also riding on the ferries in BC with the car in “Ready” mode. Currently the lights stay on and I get ferry workers urging me to turn off my car. They see the lights on and can also hear the noise of the heat pump running and think that the engine is idling, which is not allowed.
  15. Tekbar7522
    2026 Prius Plug-in
    yes it was part 84329-33080
    i got it on eBay. It was actually from a 2020 Corolla but works great. If you buy on eBay, I recommend putting a few different ones in your cart and waiting a few days. I bought one, and a couple days later I got offers from the sellers at a cheaper price. Didn’t know that was something eBay sellers do.. any questions I can see if I can help.
    mva likes this.
  16. Gokhan
    6,714
    2,672
    Paramount CA
    Or put a tiny $1 LED light you can get from a dollar store over the light sensor, which should do the trick of turning the auto-on lights off in the dark.
