Drive Motor A temp sensor circuit high
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by douglasjre, Feb 5, 2018.
  1. douglasjre
    douglasjre Senior Member
    1,884
    655
    Orlando, FL
    code p0a2d. Where is Motor A temp sensor circiut? Is that an elec motor or gas motor?
  2. JC91006
    16,482
    8,400
    That's in the transaxle, need replacement. I had a red 2010 with that error
    Raytheeagle likes this.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    Did you end up getting rid of it for the same price you paid for it:whistle:?
  4. JC91006
    16,482
    8,400
    Yep same $2k, sold in 15 minutes
  5. ChapmanF
    15,674
    Quick point about codes: because a code refers to something that's located in 'assembly X' does not always mean you should go buy assembly X and replace it. Sometimes it does, but sometimes the cause could be something simpler.
    Especially when assembly X is both expensive, and a bear to replace, it can definitely be worth looking the code up in the manual to see what its "detecting condition" is, and working through other possibilities for what could have caused that condition (the manual will have a suggested sequence of tests you can try in order to do so).
    At least that way, if you do end up at the conclusion that you need to buy a transaxle, you'll feel more confident you haven't overlooked something simpler.
    -Chap
  6. douglasjre
    1,884
    655
    Orlando, FL
    Where is the sensor?
  7. JC91006
    16,482
    8,400
    There are a couple electrical connectors that go to the transaxle, maybe you can disconnect them and see if the error goes away (or there's a problem with the connectors themselves). The sensor is inside the transaxle and can't be replaced by itself
