Driver Door FOB sensor
Discussion in 'Gen 3 Prius Audio and Electronics' started by Kpeeling, Feb 26, 2021.
  1. Kpeeling
    Kpeeling Junior Member
    30
    South Central PA
    2017 Prius v wagon
    I have a 2013 Prius
    I'm not sure what the trouble is. My key FOB controls will unlock the drivers door (actually everything) but getting close to the door, it does not work. I can open the passenger door and hatch by getting close to them (not pressing the unlock on the key fob) but not the driver's door. Also, I can lock the passenger door by touching the door sensor but I cannot lock the driver's door that way.
    Any suggestions about the cause?
    Thanks
  2. Steph1972
    Steph1972 Member
    65
    52
    St Adolphe D’Howard
    Four Touring
    Have you tried only one key fob or it’s doing the same for both ?
    And of course , have you tried to change the battery ?
    52,782
    and check the 12v
    Steph1972 likes this.
  4. Kpeeling
    30
    South Central PA
    2017 Prius v wagon
    I only have one key fob (bought the car used) and I recently replaced the battery. Actually replaced my 12 v last year before this started. It's only the driver's door. That's what makes it a mystery. Is there a sensor for each door? Does anyone know? I hate to go to a dealer. Trust issues.
  5. witheflo
    witheflo Junior Member
    boulder
    did you every figure out your door issue? I'm having the same problem.
    Thanks,
