Driver door speaker problems
Discussion in 'Gen 3 Prius Audio and Electronics' started by Dirk dinggler 48, Dec 11, 2013.
  1. Dirk dinggler 48
    Dirk dinggler 48 New Member
    I just bought a 2010 Prius with jbl sound system with navigation.i have the 8 speaker setup and my question is about the driver door speaker.driver door and left dash speaker work great with the Bluetooth but do not work while listening to radio.I took it back to the dealer and they said this is normal.Is this normal?Doesnt seem like those 2 speakers would be dedicated to Bluetooth only.
    giveupnt likes this.
  2. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    This is the Prius-v forum, BTW.
    Are you aware that you have separate balance adjustments for the different inputs? Have you checked those settings?
  3. giveupnt
    giveupnt New Member
    San Francisco, California
    I have the same problem!! pls tell me whats going on!!
  4. Anas Almustafa
    74
    28
    Arbela, Irbid, Jordan
    I had the same problem, where the driver side speaker wont work on some radio stations.
    When i switch to another strong radio station it works again. I am guessing it has something to do with Mono and Stereo HD radio broadcasting as well as weak and strong radio signals which causes the left speaker to have a weaker sound.
    Another possibility might be that the speakers lines to the head unit are mixed up where one of the 2 front speakers are connected to the 2 right speakers instead.
