Driver Keyless Entry not working properly
Discussion in 'Gen 3 Prius Technical Discussion' started by SAS, Jan 23, 2018.
  1. SAS
    SAS New Member
    LA
    Hi Everyone! Need some help troubleshooting my issue.
    Keyless Smart system does not work when using driver door handle to open. The system does work when using passenger door and from the key fob buttons. The system beeps on unlock but double locks on lock with new sound. The 12V battery is new and works fine. The driver and passenger actuators have also been repaired. Also have replaced the door master switch in the driver door.
    Looking for the next viable option to fix. Is it the door wire harness sensor Part: 8974647040 or something else. Please help.
    Thanks in advance.
    52,832
    welcome!
    probably not the issue, but have you checked the fob battery? same problem with both fobs?
  3. SAS
    SAS New Member
    LA
    I haven't checked the fob battery but the fob works on passenger door, just not driver
    52,832
    yeah, it's a very small probability.
  5. SAS
    SAS New Member
    LA
    Very small. If thats working whats the next possible culprit?
