"Driver-Only Air-Conditioner Mode"?
Discussion in 'Prime Main Forum (2017-2022)' started by mr88cet, Mar 30, 2017.
  1. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    In her Transport-Evolved channel review of the Prius Prime, Nikki Gordon-Bloomfield (
    ) at around 6:20 in the video, mentioned a "driver-only air-conditioner mode," wherein it will turn off all other vents and only burn energy on temperature-controlling the driver's area.
    I don't recall seeing that in any other video, nor in my brief test drive. Is that real, or is she … over-summarizing or maybe even misunderstanding some feature?
    If this really does exist, then I bet I'll be using it a lot. My wife always has the passenger-side (her side) vents turned off, and I don't see any other way to turn off those big vents.
    iPhone ? Pro
    #1 mr88cet, Mar 30, 2017
  2. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    S-Flow mode, described on page 489 (7 inch) and page 500 (11.6 inch). Operates automatically if it detects that there is no one in the passenger seat. Even with someone in the passenger seat it gives priority to the front seats. While carrying passengers in the rear you may want to turn it off since it doesn't detect rear seat passengers.
    Page 500
    Page 505
    #2 Since2002, Mar 30, 2017
  3. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
    Yes, the system will direct air to only the seats being used.
    It's a feature mentioned by Toyota when first revealed and had went unmentioned since. Most reviewers aren't thorough enough to notice.
  4. huskers
    huskers Senior Member
    2,550
    2,489
    Nebraska
    It seems strange to have a car with an IQ higher than the owner's.
  5. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    :p
  6. mr88cet
    2,313
    1,335
    Austin, TX
    Excellent reply, thanks!
    So, what I think I read there, is that I can explicitly select to climate-control the front seats and not the back, and then the P.Prime automatically controls right-front on/off based upon whether there is or is not a front-seat passenger currently seated.
    That sounds good.
    However, what I think I do not see is a means of turning off the air conditioning to the front-seat passenger when she *is* there. That, considering that the vents, unlike my current gen-2, do not have an on/off/amount knob.
    True?
    iPhone ? Pro
    #6 mr88cet, Mar 30, 2017
  7. EV-ish
    EV-ish Active Member
    602
    278
    SW US
    I've noticed that I can fool the occupied passenger seat sensor by raising whatever is on the seat for a moment. This has come up when the car whines that a seat-bet is not fastened for a package in the seat.
    mr88cet likes this.
  8. Since2002
    936
    1,098
    Duluth, GA
    Actually after reading the instructions again it seems that it does detect rear seat passengers, at least indirectly. If one of the rear passenger doors is opened then S-Flow is automatically turned off. Not sure if the timing matters, i.e. does it matter if the rear doors are opened before or after startup, or before the driver gets in, etc. Probably just something simple like if a rear passenger door is opened within a certain period of time prior to startup, or anytime after startup, S-Flow will be turned off.
    And I wonder what the name means. I'm guessing Smart-Flow
    mr88cet likes this.
  9. Tideland Prius
    16,683
    mr88cet likes this.
  10. Since2002
    936
    1,098
    Duluth, GA
    HPrimeAdvanced and mr88cet like this.
  11. Tideland Prius
    16,683
    Keep in mind that it is talking about the GS450h. We don't know if it can be directly compared to the system in the Gen 4/Prime. There could've been advances or the gains could be smaller (because the Prius uses a smaller compressor in the first place). It obviously is enough that the cost:benefit ratio is there for Toyota to include it.
    mr88cet likes this.
  12. liquidtenmillion
    liquidtenmillion Active Member
    261
    194
    Easley, SC
    I know this is a decent bump but I have some information that may be interesting.
    This morning I opened my rear door to get something out of the car and then went back inside. Did not start it. 10 hours later I went in and started it to drive S-Flow was turned off.
    I do not think there is a time limit, if the rear doors are opened at any time, the next time you start the car it will be off. Basically I think if the seatbelt indicators show up, S-Flow will be disabled.
    HOWEVER, I think there is a time delay if you manually override it. I turned sflow back on manually while in the car and went about my business. I turned the car off and opened the rear door and closed it and started the car again. S-flow was still on! I repeated this a few times and S-Flow stayed on.
    I then left and came back a day later, opened the rear door and then started the car and s-flow was off now.
    I think that if you overrode the default S-Flow setting at any point in time, it will not be automatically changed again until at least 12 hours later.
    I’ve seen the reverse happen too. I explicitly turned Sflow more off, and then the next few times I started the car it was off, until I started it the next morning where it was automatically on again.
    Tideland Prius likes this.
  13. Starship16
    Starship16 Senior Member
    1,348
    1,455
    Beach Christmas
    It's odd that it says this:
    However, air will always be blown from the side outlet of the front passenger seat.
    Does that mean the far right dashboard vent? When I use the S-Mode in my Gen4, I never notice any difference in air flow. All the top vents blow air. So I usually just leave the S-Flow off.
    And the poor passengers in the back seat. The only AC vents for them are under the front seats. I've tried all the settings, and very little air ever comes out of those vents. (I use High/Low vent selector). I was hoping it would also help cool the hybrid battery, too.
  14. Tideland Prius
    16,683
    Those are rear seat heater ducts. They should have air blow out if you choose the FOOT mode. For those of us who have a winter, they help heat your toes if you’re sitting in the back.
    benagi and HPrimeAdvanced like this.
