1. The site is migrating to a new server this week, so there will likely be some downtime during that process. You can follow along here for updates.
Driver side a/c vents barely blowing air out
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Pdizzle, May 26, 2023.
  1. Pdizzle
    Pdizzle New Member
    Palm Springs, CA
    Hi folks,
    Like title says, my driver side a/c vents are barely blowing air. Passenger side is working perfect. Air is coming out cool its just barely blowing any air out. I already took out the blower motor it was pretty clean. I also listened to the blower motor while turning on a/c levels, it seems to be working perfect. I'm thinking I need to clean the evaporator because it may be clogged which is why airflow is not reaching driver side vents? Just a theory I'm not too sure, any thoughts? Thanks.
  2. pdc
    pdc New Member
    Four Touring
    Hi Pdizzle...I have the same issue and was wondering if you ever found a resolution? Thank you
  3. Pdizzle
    Pdizzle New Member
    Palm Springs, CA
    I'm still trying to figure it out. I did get an a/c refresher kit and cleaned the evaporator from underneath the car although it didn't solve my problem, I can rule that out. I'm going to take a look at the blend door actuator next.
Loading...
