Driver side CV stuck....recommendations?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by FazilHussein, Jun 10, 2025.
  1. FazilHussein
    FazilHussein Member
    71
    36
    Perth, Ontario, Canada
    Good folks of Priuslandia!
    Vegemite finally needed a repair; after 425k km (~270k miles), driver side CV is clunk clunk clunking..
    Check the 'tube...looks easy enough....axle nut off, three rusty bolts for control arm off, outer cv joint swinging in the breeze..
    Then!
    Pry, yank, pull, heat, curse, tired, curse, pull, think...inner CV cup won't budge.
    Dejected I looked at the 'tube again over a plate of lasagna; couple of methods:
    1) Cut the boot of the old joint, insert, vice grip in place, yank yank yank.
    2) CV puller forks
    3) Chisel
    What has worked for you?
    Thanks,
    Faz
  2. mr_guy_mann
    mr_guy_mann Senior Member
    4,108
    2,009
    NJ-USA
    1) careful (but violent) use of the largest prybar that I get into position between the inner joint and transmission
    2) gentle (steady) use of a prybar by one person while a second uses a flat hammer attachment on an air chisel-hammer to "rattle" the side of the inner joint
    Both of these methods are helped tremendously by having the car fully raised on a lift
  3. BiomedO1
    BiomedO1 Senior Member
    4,415
    2,324
    Left Coast
    Be mindful that your prying against a relatively soft aluminum case!!!
    The transmission end needs to come out straight; so if you've separated it from the rest of the shaft that's a plus; otherwise you'll need a second person to take the "weight-off" the other end as you gently pry, reposition/rotate a bit and try prying again. It's held in by a spring clip, so repositioning and trying to pry again does help. If that spring clip is in an awkward position - no amount of prying is going to get it to release. That's why you want to take the pressure off of it, reposition and try again. It should pop right out once that clip compresses.
    Good Luck.......
  4. Tombukt2
    Tombukt2 Senior Member
    13,717
    2,483
    Durham NC
    There's a $19 tool on Amazon and other places that consists of what looks like a reg ball joint fork. Wider and another fork not tapered . Makes quick work of this trying to get two sized prys on they're sux. Not much room once one pry is in violent snap of wrist usually pops it . But many times not . they're no room on these vehicles. That fork makes it pretty painless .
    BiomedO1 likes this.
  5. Tombukt2
    13,717
    2,483
    Durham NC
    You do have the other end out of hub ???? If not you need to figure out to make strut swing away from car . A person has to hold it away from car or pull it from hub. Rest shaft on frame not hanging . Some guys use the exhaust pipe holder to keep shaft level . If it's hanging out of car notice the extreme angle you prying that circlip at.
  6. FazilHussein
    FazilHussein Member
    71
    36
    Finally had a chance to finish this job.
    Tried rotating and prying; no dice.....would not budge.
    Used the old CV joint as a puller:
    1) Cut both band straps off the old inner CV joint
    2) Slide the boot down the shaft
    3) Wipe off the grease from the spider gears
    4) Insert the spider gears back into the CV cup stuck in the transaxle
    5) Attach a vice grip to the cup to act as a block
    6) Yank!
    Out after a couple of pulls! Joy of joys!!!!!
    Rest of the job went smooth.
    Thanks for all the suggestions!
    VEGEMITE RIDES AGAIN!!!!
    Faz
  7. Hayslayer
    Hayslayer Active Member
    501
    300
    This method is tried and true and has worked perfectly for me also. I tried explaining it in another thread for a guy who ended up giving up and going to a dealer. I put a link to another discussion about it and a video, but I don't think I explained it as well as you did. Glad to see it worked well for you also. It will probably be my go-to method whenever possible.
  8. Tombukt2
    13,717
    2,483
    Durham NC
    I got this $19 pickle fork it's just rt width for our size CV axles it comes w extra bar lever . It's not too long use on ramps.
