Driver Side Engine Mount Transmission Mount. Has anyone replaced it?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by zephyrusaurai, Oct 22, 2023.
  1. zephyrusaurai
    zephyrusaurai Junior Member
    22
    Trenton, NJ
    I've been getting some vibrations and was advised by my mechanic that it could be motor mounts. I'm able to directly look at all the mounts except for the driver side. The rest look to be fine without any tears.
    Through some mirrors it appears to have some tearing to it when I compare to the pictures of a new one. Does the inverter need to be completely removed? Or can it be accessed by working around it a bit?
    The workshop manual just says...remove engine then mount so it's not too helpful on that aspect.
  2. Tombukt2
    Tombukt2 Senior Member
    13,795
    2,498
    Durham NC
    I'm standing out here at the car now and it looks like you will undo the inverter twist it and try to lay it up on the valve cover over to that side You have one mount bolt that's right there at the edge of the inverter and then of course you'll have to move the coolant bottle for the inverter I think you'll be able to leave the brake reservoir sitting the computer that's right next to the two reservoirs I think can stay when the reservoir for the inverter is moved and the inverter is flipped and over towards the engine valve cover you'll have full access to the mount I would be shocked if this is seriously causing you lots of vibration or any vibration actually but you won't know that till you change it. I guess usually you can get a pry bar in between the engine transmission up against one of the big heater hose extensions or something and try to rock the engine it's pretty solidly mounted but some people are more sensitive to vibrations than others.
  3. Tombukt2
    13,795
    2,498
    Durham NC
  4. zephyrusaurai
    22
    Trenton, NJ
    Yea I'll have to give that a shot. It's vibrations based on engine RPM so the only thing I can think of is a motor mount. Does have a small clunk when accelerating from a stop so I'm not sure what else it could be. At least the other mounts I can visibly inspect and pry against.
  5. bdc101
    bdc101 Member
    250
    usa
    What do you mean, vibrations based on RPM? Do you mean they only occur at a particular rpm, and if so which RPM range?
    Or do you mean the vibrations get worse and worse as RPM increases?
    Failing engine mounts don't really cause vibrations, and the driver's side mount in particular is only responsible for holding the engine up, not reacting to the torque of the engine (that is the back engine mount). What you describe doesn't sound like a bad engine mount to me so far.
  6. zephyrusaurai
    22
    Trenton, NJ
    Vibration at certain speed/engine RPM sounded a bad bearing. Figured out it's a noise and vibration at 55+ mph from the passenger side. Gets worse if you are doing left hand turns/bends at spend (not a cv axle clicking) Around town speeds no noise or vibration.
    Mechanic checked and didn't hear anything from the bearings. His thoughts were most likely a motor mount (didn't go in for a full inspection just him doing me a favor since I'm there and it's my only car at the moment).
    Only other thing I can think of is maybe a slightly seized caliper, but changed the rotors and pads ~1000 miles ago and it all spins freely.
  7. bdc101
    bdc101 Member
    250
    usa
    OK, but is it vibrating based on engine RPM or speed? Those are two different things. One indicates a problem with the engine, and the other indicates a problem with the drivetrain or wheel bearing. It sounds like it's vehicle speed from your description. Engine mounts don't cause that, because the engine doesn't know what speed the car is moving at, especially in a CVT car where the RPM can vary greatly at any given speed.
    Which bearings did your mechanic check? Noise/vibrations from the right front wheel area that increase with vehicle speed and increase during left hand turns is almost certainly either the front passenger wheel bearing or CV axle. (CV axles don't always click when they fail.) It could also be a bad tire - sometimes certain tires are as noisy as failing wheel bearings (and they can also be out of balance, causing vibrations at only highway speeds).
    Honestly, I would start by rotating your front tires and seeing if the noise follows the tire. That's easy and free. Unless your mechanic already tried this.
    Mr. F and Brian1954 like this.
  8. zephyrusaurai
    22
    Trenton, NJ
    Hard to tell to be honest. I'll get some vibration on cold starts when the idle is high, otherwise it'll be at 50+. It does go away as the car warms up. I had my mechanic replace both front wheel bearings maybe 2 weeks ago with OEM ones (koyo bearings). Since they appeared to have a little bit of play. Noise continued after they were installed, he rotated all tires when I brought it back in, tested (front to back...tested and then side to side and tested) ...still making the same noise. So he rebalanced all of the tires as well. Still have the noise so I brought it back and that's when he had it up in the air to go through everything again. I have been getting a single metallic clunk ocasionally when I accelerate from a full stop. Could that be motor mounts or CV?
  9. Mendel Leisk
    42,239
  10. zephyrusaurai
    22
    Trenton, NJ
    175k as of this morning. Trying not to drive it so much until I have it sorted out. I might just try for the CV axle, no clicking but the noise does get worse with speed and after rechecked the bearings...no noise from any of them. Maybe the CV took some abuse when the bearings were put in as the noise is louder than 2 weeks ago when the bearings were first put in. (I'll just do this one myself as he already did the hard part of removing the rusty bearings)
  11. Mendel Leisk
    42,239
    If you’ve never cleaned EGR and intake manifold, you’re in the danger zone for head gasket failure. That could be the cause of your symptoms: coolant in the combustion chambers (especially after sitting overnight) hydro locks the engine.
    coolant level stable?
  12. zephyrusaurai
    22
    Trenton, NJ
    EGR cleaned at 160k (pulled it all apart and used some thin wire brushes) I was debating a new one entirely. Intake cleaned out at 140k and then at 160k with the EGR. Coolant level has been stable it's whole life (marked it with a marker and its still at the same level from 140k)
  13. Mendel Leisk
    42,239
    160k is late in the day; I’d keep head gasket failure on the list of possibilities.
  14. bdc101
    bdc101 Member
    250
    usa
    Notwithstanding that the HG is liable to start going at some point... did your mechanic spot any tears in the cv boots when he did wheel bearings? If he wasn't careful you can definitely damage boots while doing a wheel bearing. However, I would expect most mechanics to take pretty good care.
    Based on what you've said, I think my next step would be replace the CV axle, especially if it has tears. However, this is what BMW owners call "the parts cannon." Not really sure, but if you really want to get this problem solved, that's what I would replace next. It's unlikely to strand you if that's the problem though, so if it was me I would probably wait until the problem gets worse and easier to identify.
  15. bdc101
    bdc101 Member
    250
    usa
    Also, after I posted I thought of one more thing - if an engine mount bolt was physically loose it could cause a metallic clicking noise when getting on or off the gas. Tightening those is free!
  16. Murtaza Darugar
    Murtaza Darugar Junior Member
    Utah
    I have been having almost exact same issue. These are the things I have done already, and I will tell toy in the end what I was told by Toyota mechanic in Grand rapids Michigan.
    2912 Toyota prius plug-in 216k miles, I changed the front 2 struts assembly and back shocks, driver side CV axel, sway bar links. Lube the caliper pin again. First when I changed the struts the car immediately felt really smooth and great under braking but as you mention from hard stop to accelerate I kept hearing that clunk. Although I was also hearing the odd click noise so decided to change CV Axle and sway bar links. The clicking noise went away and I could feel the car traction being balanced and a tighten steering compared to really loose previously. The clunky noise has decreased but is still there. I did all the work myself and have worked on 4 Prius I have owned currently have 2 3rd gens . I had the car checked with 2 mechanics before doing all of this. None was able to pin point or replicate the issue unless I would make them sit with me and drive. They don't try to listen to car at initial acceleration only when it's in momentum. I changed struts and shocked because of sharp leaning and more bounce under braking. I have made 3 trips this year 1600 miles in 2 days each. I started noticing this noise started happening after my last trip. I was sure my Axle was gone within a year of last one replaced Go figure NAPA autos. I hope this one last longer its Autozone because I wanted to check and not keep pouring money on parts and labor.
    Finally decided to give money to toyota $150 just to find the noise. In the end had to pay and do the same make the mechanic sit with me and drive just a few feet to replicate the noise.
    This is what he said which I have been having an inclination to "Even though the transmission is not showing issues its a play in the transmission that seems like the likely cause. He apparently had checked everything else and also that I told him the things I had replaced. The only other things I feel could be making that noise which all mechanics have said no to is the control arm or the ball joint. I can understand why the transmission could be doing this if the Axle was bad and caused a play in the transaxle, it's just my theory. I have decided to live with this problem as since I changed all the other parts and the car is way smoother only at hard acceleration from stop it does that. Recently maybe I'm not noticing it anymore or its decreased a lot I'm not sure or maybe I have adjusted my driving style. I would suggest changing the CV axle and check sway bar links. If you wish change the control arm or the ball joint but do let me know. Thank you!
    P.S if you take to Toyota maybe ask them to do alignment which I paid separately unfortunately and then get the mechanic to ride with you to create the noise will save you there charge and maybe get him to locate that noise.
    bdc101 likes this.
  17. zephyrusaurai
    22
    Trenton, NJ
    Yea it's not ideal, but it is what it is. Worth a shot since it's up in mileage. I didn't want to just throw more parts at it, but it is what it is. No tears in any of the boots, but the inner does have a coating of oil/grime so not sure if it leaked out all it's grease at one point or it's from somewhere else.
