Driver side power window stops at wrong position on automatic mode
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Raghav, Mar 3, 2017.
  1. Raghav
    Raghav Junior Member
    39
    I had a low aux battery some time back, and I was trying to start the car. Same time, I opened window a little bit, but battery died. I had to get it jump started. But then on, the window stops in the position it was in when the battery went out -- about 30% open. If I try to close window in automatic mode, It goes all the way up, then slides down to the "battery dead" position and stops. Is there anything I can do to fix this? Reset some settings?
  2. JC91006
    16,674
    8,519
    Roll window down and then hold the switch while rolling all the way up for 10 seconds
    goldfinger and Samprocat like this.
  3. Raghav
    39
    Thanks a lot. It worked. I had to roll window down, hold for 10 seconds, then up, hold for 10 seconds.
  4. Ed69
    Ed69 Junior Member
    39
    23
    CA
    I discovered that anytime we take the driver’s side door panel off and unplug that master window control unit, it will lose its automatic mode.
    Rolling the window all the way down and hold for five seconds, then roll it all the way up and hold for five seconds is enough to set the memory.
