Driver side window behaving oddly
Discussion in 'Gen 3 Prius Technical Discussion' started by Jayw13702, Jan 6, 2018.
  1. Jayw13702
    Jayw13702 Active Member
    142
    170
    Plymouth UK
    My drivers window has started behaving oddly, when it’s closing it stops and then opens again, when I then try and close it the same happens after only a second or so.
    I’ve checked for obstructions and there are none, I know the motor is activating the anti-trap but even after cleaning the runners and squirting silicone live down then it still does the same.
    I have a video of it doing it but don’t know how to post it.
    Any ideas on what to look for next?
    2010 Gen 3
  2. padroo
    padroo Senior Member
    2,763
    2,253
  3. Johnny Cakes
    Johnny Cakes Senior Member
    1,065
    789
    Virginia, USA
    Prius initialization procedure when the power window does not fully open or properly close:
    (1) Turn the power switch on (IG), or hold POWER for 5 seconds.
    (2) Fully close the power window by fully pulling up the power window button, and hold the button for 6 seconds or more after the window is fully closed (if the power window does not move or stops halfway even when the switch is fully pulled, release the button and fully pull it again).
    (3) Fully open the window by pushing down the power window button, and hold the switch for 1 second or more after the window is fully opened.
    (4) Release power window button. Then fully push down and hold the switch for 4 seconds or more.
    (5) Fully close the power window by fully pulling up power window switch, and hold the switch for 1 second or more after the window is fully closed to reset the glass position and complete the initialization.
    Raytheeagle likes this.
  4. AzWxGuy
    AzWxGuy Weather Guy
    1,080
    558
    Tucson, AZ
    2021 Prius
    And if your battery wasn't disconnected recently, you should probably check your 12V battery health.
  5. padroo
    2,763
    2,253
    Is the procedure the same in all years? Looks like his is a 2010.
  6. Jayw13702
    142
    170
    Plymouth UK
    Here’s the video of the window in action
    2010 Gen 3
  7. Jayw13702
    142
    170
    Plymouth UK
    That appears to have cured it, thanks for the info
    2010 Gen 3
  8. DogDaze
    DogDaze Member
    203
    44
    Bay Village
    I guess I get to try this reset procedure tonight.. It's been fine, but this AM I rolled it down.. went to put it back up and it went about 1/4 of the way and stopped.. put it down and back up and it stopped in the same spot.. put it down all the way and it came back up.. so, thinking that it was just a fluke, I put it back down again. (stupid me) and it did the same thing.. stopped at ~1/4 of the way.. I had to put it down 2 or 3 times before it came all the way back up.. but figured I wouldn't touch it until I could research and I have it closer to home.. (like in the garage)
  9. DogDaze
    DogDaze Member
    203
    44
    Bay Village
    this procedure actually worked for me, the others above did not work:
    Reset Window Motor on Prius
    Reset (initialize) Power Window Regulator Motor
    Resetting the power window motor is necessary when the battery terminal is disconnected; when the power window master switch, window motor, wire harness, or window regulator is replaced or removed. Otherwise the Auto operation function, Jam function, and remote operation function will not work.
    Here are the steps:
    A. Turn the ignition switch ON.
    B. Halfway open the power window by pressing the power window switch.
    C. Fully pull up the switch until the window is full closed and continue to hold the switch for approximately 1 second after the window is fully closed.
    D. Check that the Auto Up/Down function operates normally.
    If not operating normally, follow these steps.
    1. Disconnect the negative battery terminal for 10 seconds.
    2. Connect the battery terminal.
    3. Follow steps A-D above
    Reset Window Motor on Prius | Auto Glass Jim
    I believe that we'll be replacing the 12v battery in the near future.. (it's still original)
