Driver side window goes up then down a little bit-window calibration help needed
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by SLO Cat Wrangler, May 22, 2011.
  1. SLO Cat Wrangler
    SLO Cat Wrangler Junior Member
    96
    San Luis Obispo, CA
    Hello everyone,
    I have a 2008 Prius, but my wife drives it. I think this problem has been going on a long time, but because my wife drives the car, I never noticed it. When I raise switch to raise the window on the driver side there is a little click after which the windows should roll up to the top and stop with out holding the window switch.
    Mine does this, however it gets to the top and then drops back a little. This does not happen if you don't engage the automatic roll up feature.
    I found a couple of threads that talked about window calibration, but I cannot find anything more than that.
    I found this link but it just goes to the home page of priuschat
    PriusChat | Toyota Prius Forums, News, and Accessories
    any help is most appreciated.
    Thanks
    Steve
  2. dogfriend
    7,512
    1,188
    Carmichael, CA
    Instructions for resetting the auto up window. You might have to disconnect the 12v battery for a few seconds, but I would try it without first.
  3. SLO Cat Wrangler
    96
    San Luis Obispo, CA
    Thanks for the help. I'll give it a try
    Steve
