driver side window or door rattle noise at low speeds
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by kwhubby, Jul 8, 2013.
  1. kwhubby
    kwhubby Junior Member
    27
    San Jose
    Hello,
    I've seen a thread about this in prius II and prius III forums, but no mention with the prius C.
    I've been recently very annoyed by a sound I can hear when driving between 5 and 40 mph. It sounds like the window or door seals/weatherstripping is repeatedly losing static friction to a shaking door or window. If I push forcefully outwards on the window the sound seems to be reduced.
    I have about 22k miles on the card so far. I'm assuming I should go to a dealership, but I'm afraid some of them will dismiss the problem with some excuse or another. I wonder if any dealership in my area would be more apt to solving this type of issue. I'm in San Jose, CA and I've been to both Sunnyvale, and Piercey toyota for regular service intervals.
  2. Drdiesel
    Drdiesel Active Member
    585
    152
    Monterey CA
    I would go to Piercey over Sunnyvale for anything. I've been to both on a professional
    level and Piercay is by far a better service department :eek:
  3. wmo168
    wmo168 Member
    239
    50
    South Florida
    Yes the weatherstrip does make noise, try putting armorall on it and see if it eliminate it.
  4. kwhubby
    27
    San Jose
    Armorall? Interesting, I was thinking I might try Vaseline or some other oil.
    Do you think a dealership would just do the same? I might be able to save some hassle if I could just buy a bottle.
  5. wmo168
    wmo168 Member
    239
    50
    South Florida
    buy a bottle and return it if it doesnt work. make sure you get it in between the weatherstrip on the door as well as the one on the body and in between.
  6. optimus prii
    optimus prii Junior Member
    16
    So Cal
    I have the same problem. The dealer charge me $100 to "fix" the rattling sound.
  7. orenji
    orenji Senior Member
    5,884
    3,486
    I have just developed the same, now that it is cooler, it sounds like the body is flexing and the door seals are moving against the body. So if i armorall it the seals, it will eliminate this problem? How about strut brace or trans tunnel brace?
  8. TrafficMPG
    TrafficMPG Junior Member
    Be careful with petroleum based products like Vaseline. They will eat away at rubber. It's better to use silicone based.
  9. camelott
    camelott New Member
    boston, ma
    after 20k miles notice a thump which seems like in right passenger door and a ticking sound nearby.
    it could be in the A pillar (TSB 0064-12) or in door itself
    feels like glass in passenger window rattles
    prominent over bumps
    dealer says he does not hear anything , which is impossible
    going to another dealer
    car is under warranty, any suggestions?
    I WILL NOT let Toyota off the hook.
    Others have the problem I have as I have read different accounts.
