Driver window works, driver master window controls/lock doesn't.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Johnsmith009, May 15, 2019.
  1. Johnsmith009
    Johnsmith009 Member
    124
    34
    Mississauga, Ontario, Canada
    In the past few days,
    -Every time you want to adjust the windows in any seat, you have to press the button twice. Holding it does not work either, it has to be pressed once, then it will work the second press. The responsiveness period is maybe 5 seconds of INACTIVITY (will remain functional if you keep adjusting them), then you have to do this again.
    -I can roll down the window on driver's side, NO auto.
    -I can adjust the mirrors.
    -Each seat can adjust its own window (regardless of the master lock setting), WITH auto.
    -I cannot lock the doors.
    -Passenger can lock the doors.
    -Both rear windows almost sound like the motor is low on power.
    First stop, what fuse should I be looking for?
  2. Agristal
    Agristal Junior Member
    US
    Hey, did you ever get this solved? Just happened to me; fine last night, but not working in the morning.
  3. Johnsmith009
    Johnsmith009 Member
    124
    34
    Sorry for the late reply: No, I never did. Just been dealing with it since.
    52,854
    sounds like an ecu issue
  5. Johnsmith009
    Johnsmith009 Member
    124
    34
    Appreciate the reply, and not that this is still a high priority for me but are you sure?
    I have no idea why I neglected to mention in the original post that a week before it started happening, I left my driver side window open when it rained.
  6. mr_guy_mann
    mr_guy_mann Senior Member
    4,117
    2,012
    NJ-USA
    So you almost certainly got water into the madter switch assembly, and possibly anything else in the door.
  7. bisco
    52,854
    no, i am not sure. pretty difficult to hard diagnose over the internet.
    i would agree with guy, looks like the source of the problem. but then again, i'm not sure.
