Driverless Prius on the move - not what you think
Discussion in 'Gen 4 Prius Technical Discussion' started by plug-it-in, Feb 9, 2017.
  1. plug-it-in
    plug-it-in Active Member
    179
    113
    Kitchener, ON, Canada
    Toyota had a recall on the Gen 4 cars because they under some circumstances the car would move - drive itself forward without a driver in the car.
    It is darn easy to do with cars using the Start/Stop buttons instead of keys. Here is an example: you are driving to your mailbox, your car keys are in your packet sharing the key ring with the key to the mailbox. You stop the car, press the (darn) foot break and leave the car, door open etc. to make the two steps to the mailbox while fishing out your key ring from your packet to open the mail box. Now the car is in "D". If that (darn) foot break is not properly pressed down the car can "creep".
    I just read GM fixed this problem in the Bolt. The system software senses if there is no one in the driver seat or the seat belt is not fastened. If so the software will put the car into Park. What a brilliant fix and cheap!
    I have no idea how Toyota fixed my car. But a few lines of code seems an easy answer.
    pilotgrrl and RCO like this.
    52,819
    what recall? why wouldn't you put it in park? would you leave a gasser in drive and get out with the footbrake on?
    pilotgrrl, pjm877, kithmo and 5 others like this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,167
    Tampa, FL
    Agreed. WOW. I have never heard of anyone deliberately getting out of a car that was not in park unless they wanted it to move while they weren't in it.
    pilotgrrl, kithmo and 'LectroFuel like this.
  4. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    The bolt has a confusing shifter. The Prius has a button. A button. It can't get much simpler than that! On my car they added a notch to the parking brake line to make the brake stay in place.
    pilotgrrl and bisco like this.
  5. bisco
    52,819
    no added code?
    RCO likes this.
  6. 'LectroFuel
    880
    673
    If you are talking about a computer code, no.
    bisco and RCO like this.
  7. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    You'd have to really try HARD for this scenario to happen. If you open the door - it beeps, and shows a big red door on the display. If you did get out and walk away from the car, it starts moving immediately and would likely run you over before you got to the letter box.
    There was a recall on the handbrake (foot-hand-brake thingy - the logic of it escapes me) to install an extra clip - I had mine installed this week.
  8. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    FWIW, I thought plugitin missed a gear between brain and mouth and thus, got his foot brake and parking brake confused. It certainly made a bit more sense then.
  9. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
    Every time man creates a foolproof product nature creates a better fool.
    pilotgrrl, xop, kithmo and 2 others like this.
  10. PHDRPH
    PHDRPH Junior Member
    25
    17
    Yes the parking brake recall fix did help. I noticed before the fix, in cold temp you start the Prius and the petrol engine kicks on. And if you did NOT have the parking brake on it would move forward. Now it's ok. But the passenger airbag recall is upsetting. Toyota should have addressed this issue before letting the 2016 Prius off the assembly line. Anyone get the fix yet.? If so did your dealer put the dash back ok?
    iPhone ?
  11. 'LectroFuel
    880
    673
    I also had the airbag done and they put everything together well.
    RCO likes this.
  12. bisco
    52,819
    there is at least one thread here on people that have had the airbag recall done.
    i rarely use the parking brake, but i have my foot on the brake when the engine starts.
  13. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    That to stop the car shake, or the DT's? ;)
  14. alanclarkeau
    7,045
    7,593
    No it wouldn't move, because you'd have your foot on the footbrake when starting. Starting the Petrol Engine has nothing to do with it, as, if you took your foot off the footbrake, it would creep forward whether the Petrol Engine is running or not.
    RCO likes this.
  15. Prodigyplace
    12,711
    11,848
    Central Virginia
    Why reply to a 6 month old thread?
  16. alanclarkeau
    7,045
    7,593
    That's ODDDDD!! It came up as a new response on my list of Alerts this morning - so I responded - didn't check the date.
    Now that I checked - it wasn't a response at all - just someone, 6 months later, responded with a upload_2017-9-14_11-18-18.png .
  17. bisco
    52,819
    funny, i saw it as new as well. only to find out i was the second poster. i think the o/p had a few too many, as well as our software. more odd happenings?
  18. alanclarkeau
    7,045
    7,593
    Possibly - I couldn't get into PRIUSCHAT most of yesterday - kept getting errors. Working fine today.
    RCO likes this.
  19. goldfinger
    535
    403
    Buffalo
    Priuschat, skynet, what's the difference. I blame computers.
    kithmo, RCO and bisco like this.
  20. bisco
    52,819
