Driver's door Smart key sometimes fails
Discussion in 'Gen 4 Prius Main Forum' started by dslomer64, Jan 9, 2017.
  1. bisco
    52,863
    i was resonding to michelle in the post above, doesn't matter with your problem, other than the other door worked 2 out of 4 times. honestly never heard of this before. can't imagine what cold has to do with it, but maybe there's a caveat in the o/m.
  2. dslomer64
    dslomer64 Member
    157
    Cincinnati, OH
    "Make sure to touch the sensor on the back of the handle." Never knew there was one. No such rule for my '06. But I'll keep this in mind. Thanks. Guess I should read whole manual. Again. Painful experience, though.
    Gen 2 (2006) and Gen 4 (2017)
    52,863
    you got that right. maybe just ignore it, and it will go away, eventually.
    Priifan and RCO like this.
  4. dslomer64
    dslomer64 Member
    157
    Cincinnati, OH
    The dealer, my wife, and I decided today to wait until I am allowed to take off my heart monitor (in ten days) to further pursue a fix, assuming it's causing interference, since problems only began AFTER beginning to wear it December 29, my wife pointed out. Reasonable?
    However, I'll read up on how to properly open doors, even though I assure you I never had a frequent problem for ten plus years with my '06.
    I'll keep data, mentally, about whether gloves or grasping door handle's opening sensor (once I locate it) suggests a pattern.
  5. bisco
    52,863
    that's probably it, there's a warning about pacemakers.
    dslomer64 likes this.
  6. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    I remember when I could set the pace. (there's no wistful emoji on here!)
    Priifan, bisco and dslomer64 like this.
  7. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    …it's right there on p. 37 (Destruction Manual for my 2009 Gen II - but the 3-second rule has caught me out a few times! ;))
  8. Prodigyplace
    12,716
    11,848
    Central Virginia
    I just started looking at the 2006 manual and see this caution.
    Manual is at http://www.toyota.com/t3Portal/document/om-s/OM47520U/pdf/OM47520U.pdf
    kithmo, RCO and dslomer64 like this.
  9. Prodigyplace
    12,716
    11,848
    Central Virginia
    Unlocking from the 2006 manual.
  10. Prodigyplace
    12,716
    11,848
    Central Virginia
    This looks interesting too
  11. dslomer64
    dslomer64 Member
    157
    Cincinnati, OH
  12. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    The locking sensor is marked on the forward outside of the handle, my understanding and experience is that the entire INNER surface of the handle is the unlocking sensor.
    RCO likes this.
  13. Prodigyplace
    12,716
    11,848
    Central Virginia
    I do not always touch the handle if I am just unlocking the car. I just place my fingers between the handle and the door.
    alanclarkeau likes this.
  14. dslomer64
    dslomer64 Member
    157
    Cincinnati, OH
    Reporting back, as promised (?). A particular pair of gloves seems to cause erratic opening. Bare hand never a problem. Same so far with different pair of gloves. Haven't tried problem gloves on '06. Assume same erratic opening. If not, I'll be bahck.
    RCO and bisco like this.
  15. bisco
    52,863
    when i have gloves on, i usually have to try several times to lock, pressing very hard. unlocking is never an issue.
    RCO likes this.
  16. alanclarkeau
    7,045
    7,593
    I've never tried opening it with gloves on - that would be when I'm either welding; or pruning the hedge.
    #56 alanclarkeau, Jan 31, 2017
    Priifan, WilDavis and RCO like this.
  17. WilDavis
    2,493
    2,155
    49
    Welding the hedge? (…I guess it must be an Aussie thing! o_O) ;)
  18. alanclarkeau
    7,045
    7,593
    :sneaky: now edited - added a semi-colon.
  19. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    Mate, I liked it when you were using the anti 'roo hedge! Varmints.:ROFLMAO:
    Priifan and alanclarkeau like this.
  20. WilDavis
    2,493
    2,155
    49
    Anyone else remember "The Rabbit-Proof Fence" (2002)? …great film from Oz!!! :)
    Priifan, RCO and alanclarkeau like this.
