Driver's floor mat
Discussion in 'Gen 3 Prius Main Forum' started by ukulelegeek, Jan 4, 2023.
  1. ukulelegeek
    ukulelegeek Active Member
    159
    112
    I've read that the driver's floor mat is to be removed by a technician only. I want to clean under mine, is that true?
  2. bettergolf
    bettergolf Active Member
    495
    370
    Sanford NC
    Oh no!!! I've taken my driver's floor mat out many, many times and vacuumed under there....I wonder what I might have messed up?
    Grit likes this.
  3. Elektroingenieur
    2,515
    3,288
    Three Touring
    It’s important to secure the floor mat properly, as described in the Owner’s Manual (PDF), page 384, so it can’t interfere with the pedals, but there’s no reason you can’t remove it for cleaning.
    The special attention to driver’s floor mats is a legacy of the unintended acceleration scandal, for which Toyota suggested floor mats—rather than problems with the electronic throttle control system—as a possible cause.
    ukulelegeek and w84me like this.
  4. ASRDogman
    ASRDogman Senior Member
    8,066
    4,089
    It doesn't say what TYPE of technician you had to be. I certify you as a toyota
    floor mat technician! Have at it!
    ukulelegeek, CR94 and Johnny Cakes like this.
  5. bisco
    52,855
    ignore the floor mat nonsense, it came from an accident in a lexus that had two non lexus floormats stacked on top of each other, and they rode up and the acc pedal got stuck behuind them after the nutty driver floored it showing off.
    i have never had a problem with the stock mat, or the pedal, and you won't find many reports here of anyone else who has either.
    it's toyota lawyer nonsense
    ukulelegeek and CR94 like this.
  6. Grit
    Grit Senior Member
    6,577
    4,231
    Wilkes Land
    Finance technicians are also included!
    ukulelegeek likes this.
  7. Mendel Leisk
    42,347
  8. ukulelegeek
    159
    112
    Well, I took the advice of your savvy folks here, lifted it out and vacuumed the crud out from under it. Thanks!
    fuzzy1 likes this.
