Driver's Parking light connector won't lock in
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Blu-ray, Feb 10, 2013.
  1. Blu-ray
    Blu-ray Blizzard Brigade #215
    471
    198
    TampaBay, FL
    I replaced my standard parking lights with LEDs. The passenger side was a snap and super easy took all of a minute. The driver's side wasn't so. :eek: It was easy to get out and replaced the bulb with the same type as the passenger, however I can't get the bloody thing to lock in the hole.
    Has anyone had this issue or know a trick to this? I took out the LED and put the old bulb back in thinking maybe that side was a little different. It still wouldn't lock. It goes into the hole just fine. The connector looks good so I'm not sure what the issue is?
  2. john1701a
    john1701a Prius Guru
    12,840
    5,312
    58
  3. ny_rob
    ny_rob Senior Member
    1,968
    814
    L.I.- NY
    I just did my parking lamps today- new LEDs to match the 4.3K HID's.
    The connector has 4 tabs- three are large, one is small. The housing will only accept the connector when it's oriented correctly. So you have a 1-in-4 chance of lining up the connector on the first shot- I just kept rotating my connector 90 degrees clockwise each attempt till the small tab on the connector finally lined up with the small slot on the housing (it took me 3 tries BTW on the drivers side).
