Driver's seat height safety problem
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Bruce vanNorman, Jun 2, 2013.
  1. Bruce vanNorman
    Bruce vanNorman Junior Member
    26
    - The placard is right next to the fuzzy dice :) Seriously, the Prius's double glove compartment is great. We keep the placards, registration papers, and emergency kleenex in the upper one and all the junk in the lower one.
    - That certain age is 70 (State Farm in Washington - 2% increase) and the AARP senior driver class knocks off 5%.
  2. Bruce vanNorman
    26
    hello?
  3. Daniel Moore
    Daniel Moore Junior Member
    29
    Cramerton NC
    Some one tell me how to raise and lower the drivers seat, I've pumped that damn handle for six weeks I've had it, nothing happens. Am I missing something here, nothing in the drivers manual, give me some help. Got a model 2.
  4. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    It's not clearly explained in the manual, but it's a pump so it requires you to do several lifts up or down. Don't just push or pull it once.
  5. Bruce vanNorman
    26
    It's been over 2 years. The Amazon - Travelmate 3.5" wedge cushion has worked quite well for my wife. We still readjust the seat full up and full down several times per day. I have added 2" quarter circle mirrors to the lower inside of each wing mirror. They are set so when we can see a bit of the car in the stick on mirror, the wing mirror is correctly positioned. And I added a Fresnel lens (the kind they use on RV's) to the rear window. Have been thinking of adding a Gosher's blind spot detectors the last few months because of high speed bicycles whizzing past us as we try to turn into underground parking lots. FYI. we are well into our 70's and have been married for 50 years.
  6. Bruce vanNorman
    26
    It takes about 30 full pumps to go between full up and dull down. I wonder if the seat height adjuster will ever wear out?
  7. Katherine28
    Katherine28 New Member
    Newport, Oregon
    I have a 2011 Prius and I'm 5'4". I thought the driver's seat was higher before, now the seat sitting on the floor and I can't see past the windshield wipers. I took it to the Toyota dealer and the guy said that it was not an electrical adjustable seat. I went on Amazon and found a nice sturdy cushion that raises me 2-3 inches and I still can't see over the wipers. This truly is a safety problem because in essence, my view does not have a front end. Part of this is the height of the seat, and the other part is that the front end slopes deeply, so I have little reference for distance. So, does a non electrical driver seat have a manual adjustment?
  8. fuzzy1
    10,701
    Of course it is not electrically adjustable. The lower trim models have manual adjustments, including height. I always set it to the bottom, my spouse always moves it to the top.
    o_O:eek::whistle:
    Yes, it does have a manual adjustment. Open up the Owner's Manual for details on how to adjust it.
    This case isn't a car maker safety issue, it is an operator error.
