Drivers Side Carpet Wear
Discussion in 'Gen 3 Prius Main Forum' started by rstark18, Feb 21, 2010.
  1. prev93
    prev93 Member
    63
    Califon, NJ
    Are you saying that the Weathertech mats also cover the left side foot rest to prevent the wear that occurs prematurely there?
  2. ibnird
    ibnird New Member
    61
    SF Bay Area
    I was going to buy an aftermarket mat but didn't want to pay, so I did this instead:
    The car came with black Toyota floor mats, but because I'm silly I wanted to keep them clean, so I went to Home Depot and bought some black, thin, rubber-backed carpet off a roll for about $10 (US). Then I used the Toyota floor mats as a pattern and cut out some mats, which I place on top of the Toyota floor mats. So that is the carpet on the bottom, the Toyota mats on top of that, and my cut outs on top of that. Oh, I did make my patterns slightly larger so as to keep all the dirt on my $10 plus labor cut outs. I did replicate the hole in the driver's side where the hook keeps it from slipping forward. I attached it with heavy duty string, like a shoelace. Looked very good I thought.
    That was fine and dandy until I read this thread, went out and noticed that sure enough, the mats don't protect the area at the front of the footwell under the brake and gas. So I got a piece of grey thin carpet for less than $2, again at Home Depot, cut it roughly to size, and secured it under my black cut out mat, tucked up and under the plastic trim pieces next to the gas and foot brake, and secured with a couple pre-existing bolts at the front part of the footwell. I think it looks fine because the grey carpet is thin enough to pretty well follow the contours of the floor where the left footrest drops down to the carpeted area. It is secure enough for me not to have any reason to believe that it could interfere with the accelerator or brake.
    I do not bring a lot of water or dirt into the car with my feet, so this solution works for me. If I live in muddy or snowy places I'd probably buy a rubber aftermarket mat like the Weathertech. Heck, if I wasn't so cheap I would have done that, regardless.
    In retrospect, I should have just extended my original cutouts forward enough to secure them in the front with the bolts. I'll do that if I've ever the need/desire to do it all over again
  3. rstark18
    rstark18 Member
    442
    75
    Los Angeles
    One other high wear area I noticed was on the pasenger side at the lip were the plastic plate is that covers the vin (I think it's the vin it covers). I see that some pasengers are resting their feet on this area and the carpet has wear.
  4. colfacs
    colfacs New Member
    34
    louisiana
    My Weathertech mats cover the left side.
  5. rstark18
    rstark18 Member
    442
    75
    Los Angeles
    I finally got around to buying Weathertech Digitalfit floormats. I am going to return them as I really don't like them. Compared to the OEM all weather mats that came with my Priusm, they look and feel cheap. Also, they only cover about half the dead pedal. I think I'll go to Home Depot and get some dark gray all weather carpet (the come as small door mats) and cut and heat them to fit the Dead pedal footrest area.
  6. 32kcolors
    32kcolors Senior Member
    5,683
    954
    124
    Redondo Beach, CA
    That is why we need to do this.
  7. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    Here is my solution, Weathertech Floor Liners.
    Please excuse the dirt.
  8. rstark18
    rstark18 Member
    442
    75
    Los Angeles
    After my trip to Home Depot, this is what I came up with.
  9. Aegison
    Aegison Member
    404
    32
    36
    Southeast MI
    There are two things which have worked well for me on the issue, mentioned in posts in the thread, about keeping the carpet protected, and about Weathertech overflow.
    First, I found that a couple cans of 3-M rug protector will more than cover the carpet so that any water etc which gets on them can be cleaned up in a reasonable time. (PS - I sprayed the carpeted floor mats too).
    Second, when the weather has been severe enough that I get any real amount of standing water in the Weathertech's, I get it out. Used to use throw-away rags from O'Reilly, but found a small (and easily carried) $25 shop vac which can pick it up quickly and easily. Results are that, despite some deep snow etc., no overflow at all.
    The issue of the extra wear where you foot rests is one I'm still trying to figure out how to handle. I may visit my local upholstery shop and see if they can sew something into that area -- don't know if it should be leather, plastic, or something else.
  10. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
    So, with just over a year on the car, do you think the bald spot on my carpeted mat would be covered under the bumper-to-bumper?
  11. 32kcolors
    5,683
    954
    124
    Redondo Beach, CA
    What do you think?
