Driver's side headlight goes on and off
Discussion in 'Gen 2 Prius Technical Discussion' started by lilrdwgn, Jul 25, 2006.
  1. lilrdwgn
    lilrdwgn New Member
    32
    Winston Salem NC
    I recently parked beside another Prius (04-06) and when I came back to my car 1 and half hours later, the other Prius was gone.
    Well, my Smart Key would not unlock the car but the key fob would. Thought nothing of it until I got home.
    When I got out of the car with the power off, the driver's side headlight would go on and off slowly.
    I called the dealership and they told me to reset the Smart Key system by turning the switch off and back on under the dash.
    That solved the headlight problem but the ? remains why did this happen? Smart Keys are that sensitive to one another.
    Prius's don't play well together? :)
    Anybody else had this issue?
  2. mssmith95
    mssmith95 Michael
    535
    Valencia, CA
    <div class='quotetop'>QUOTE(dloftis @ Jul 25 2006, 08:05 PM) [snapback]292368[/snapback]</div>
    Extremely doubtful the other Prius had and effect. First off, you don't even know if the other car had the SKS system. Secondly, the remotes use millions of codes, which roll over each time. Even if the other car was the same as yours, it only would have functioned as yours would have. Chances are it was some other "glitch". Keep an eye on it to see if it happens again.
