Driver's side rattle... Please help!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ktyler2, Mar 17, 2015.
  1. ktyler2
    ktyler2 Junior Member
    25
    Utah
    I have a terrible rattle by my left ear whenever I drive over about 25MPH. It seems to be coming from in between the front and rear doors on the driver's side. I have banged around on the plastics but nothing seems to fix it. Does anyone have any suggestions? Should I just take this into a dealer?
  2. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    Have you checked the plastic floor pans fastened to the underside of the car to see if one or more fastenings have come adrift.
    John (Britprius)
    52,360
    seat belt?
  4. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    I would have a friend drive it and get in the back seat where you can concentrate on locating the noise instead of driving. we did that at the dealer alot to locate noises.
    Okinawa likes this.
  5. ktyler2
    25
    Utah
    I'll definitely find someone to hop in the car with me. As for now, it sounds like it's coming from in between the two windows on the drivers side. I also noticed that if I pushed firmly on the front window with my left arm while driving, the vibration does not continue. As soon as I remove the pressure, the rattle resumes. I'm not sure if this means it is inside the window well, but for some reason this stops the noise!
  6. 69shovlhed
    2,170
    752
    Delaware
    sounds like you may have to take the door panel off and look inside. but I'd do the test drive first just to make sure.
