Drivers side view mirror visibility
Discussion in 'Gen 4 Prius Main Forum' started by thewraith, May 1, 2019.
  1. thewraith
    thewraith Junior Member
    67
    23
    DC Metro
    Is it just me or is the drivers side view mirror on a gen 4 useless or close to impossible to adjust? If I adjust mine to see cars close by next to me, I have no idea whats going on further back if I adjust it to see further back- anything close to me is useless. Any aftermarket solutions? I installed the little sticky round mirrors on the side, but the image is so small from those that it's not going to work out.
    52,854
    my gen 3 is the same, i thought all cars were?
  3. thewraith
    67
    23
    DC Metro
    I owned a gen 3 and didn't have the same issues, I've cycled through 50ish cars in the past ten years and have never had one this bad. In the DC Metro- this is becoming a big issue for me.
    52,854
    is it not as wide as gen 3?
  5. thewraith
    67
    23
    DC Metro
    Not sure, but I had no issues w/my Gen 3. I put 40k miles on that and have put 40k on the gen 4 now. I've constantly adjusted my seats, my mirror, etc. Still same issue and too many close calls.
  6. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Have you tried turning your head to see what's close up ? :rolleyes:
    WilDavis and krmcg like this.
  7. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Never noticed a problem. I've driven lots of different cars, and PRIUS is about normal. I use them for reversing and parking all the time, and on the road, never noticed any issues.
    But then - we sit on the opposite side of the car.
    WilDavis and Harters like this.
  8. CooCooCaChoo
    CooCooCaChoo Senior Member
    962
    544
    Cow-lee-fornia
    2023 Prius
    I have my mirrors set to cover the blind spots. Driver's side, I'd say, is about 90% coverage. There's a tiny spot there still though.
    alanclarkeau likes this.
  9. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    As Alan says, having the steering wheel on the right side of the car helps :p
    I don't have a problem, it seems to be the same as any other car I've owned or driven and mine also has the blind spot monitoring on the mirrors which TBH I don't need.
    It could be something to do with how close you sit to the steering wheel as well, different angle of view etc.
  10. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    Here's the way I use (which has never failed me… …yet! (…but, as they say YMMV!))
    https://www.cartalk.com/sites/default/files/features/mirrors/CarTalkMirrors.pdf
    - Good luck!
    krmcg likes this.
  11. JosephG
    JosephG Active Member
    115
    102
    2018 Prius
    I've definitely notice a small blind spot just behind the B pillar that is hard to see even with the mirrors aligned correctly to see the side of the vehicle. On the passenger side it's no problem because I can see it easily by turning the head, but in the driver's side it can be hard to catch.
    It's really only a problem at night when the headlights go into blind spot. During the day, even the smallest car is visible despite it.
    I usually just merge slowly and peek out the window as I cross the line, but the semi truck drivers are so aggressive these days, I decided to put a blind spot mirror (the type that attaches to the inside of the driver's side window by suction). It's fixed the problem, but if I could do it over again I would probably go up a trim for BSM.
    #11 JosephG, May 2, 2019
    krmcg likes this.
  12. JosephG
    115
    102
    2018 Prius
    Sorry, I can no longer edit. My mirror is one of these things. (Don't worry, I was stopped at a very long light for bicycles when I took this!)
