1. The site is migrating to a new server this week, so there will likely be some downtime during that process. You can follow along here for updates.
Driver's window moulding
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by rljan, Sep 18, 2012.
  1. rljan
    rljan Junior Member
    Las Vegas, NV
    The rubber molding at the bottom of my wife's driver's window (2007 Prius) has separated. Is replacing this molding a DIY job or do I need to pay the dealer? If I can do it myself, are there any tips for removing the old molding & installing the new?
  2. Avi's Advanced Automotive
    Avi's Advanced Automotive Independent hybrid repair shop
    775
    359
    There is a common moulding that tears, however, if you could post a picture I can make sure to give you the correct advise. The usual one is a DIY kind of thing, I just don't want you to mess something up just in case it isn't.
  3. rljan
    rljan Junior Member
    Las Vegas, NV
    The molding is along the bottom of the driver's window. Thanks for your help.
  4. Avi's Advanced Automotive
    775
    359
    Part # 75720-47010
    All you need to do is open the door, pull the end of the moulding up as shown in the attached picture then pull the whole thing away from the other end of the door. Once you pull it up the other end will slide out of behind the mirror. Then slide the new one in and drop the other end in.
    boulder_bum likes this.
  5. rljan
    rljan Junior Member
    Las Vegas, NV
    Thanks for your help. I was hoping that was all I needed to do.
  6. boulder_bum
    boulder_bum Senior Member
    1,371
    38
    Castle Rock, CO
    Awesome! This helped me out, too. Thanks!
    By the way, the dealer wanted to charge $70 for this part, but someone on Amazon sold the OEM part for only $40.
Loading...
