Drives like a lamb, Roars like a lion!
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by yortlecti, Sep 6, 2016.
  1. yortlecti
    yortlecti Junior Member
    40
    Toledo, OH
    Hi all,
    I picked up a 2010 Prius V package last week with 162,000 miles. I got it from the original owner, and it is in incredible shape. My only complaint/concern is the level of road noise.
    Now, for a bit of background, I am coming from a 2006 Prius with Goodyear Assurance tires, and this 2010 is significantly louder. It is a roaring sound, coming from the back, fairly constant in nature, but noticeably louder at highway speeds. The 2010 has Michelin Premier A/S on all four. Of note, the two in the back are very new: one is around 1,000 miles, the other is about a week old.
    My dad drives a 2010 II package and he said my car was quite a bit noisier than his when he test drove it, so I'm assuming it's something is out of whack.
    My questions are these:
    Could new tires be causing the roar? Should I have them rotated and see if the noise moves to the front?
    Could it be bearing(s)? It's harder to determine with rear bearings, as the slalom test isn't as effective on non-steering wheels.
    Have any other Gen II to Gen III converts noticed an dramatic increase in road noise after the switch?
    The collective brilliance of of this forum is much appreciated, as is your input!
    Thanks,
    Michael
  2. Tariq87
    Tariq87 Member
    87
    28
    jordan
    If you install a winter tires..they will make roaring in a high speed ..because they have Rough surface..
  3. grnd0
    grnd0 Member
    42
    26
    I would say bearings. I just replaced a rear on my 2010 with only 53,000 miles. Suggest
    after driving highway, as quick as you can, feel your wheels at center. I did that and found
    my right rear was much hotter than the rest. It wasn't making noise because it wasn't bad
    enough. Need to remove hubcaps to check wheel temp. I did a shim to correct alignment
    and new hub at same time. Old bearing felt a little notchy.
  4. yortlecti
    40
    Toledo, OH
    I don't believe the Michelin Premier A/S are winter tires, but I could be mistaken. I've never heard a loud Michelin before, come to think of it, that's why this surprised me.
  5. yortlecti
    40
    Toledo, OH
    Can I ask which brand hub you ended up using, and how bad the replacement process was? I do a lot of the work on my cars, but I wouldn't call myself a mechanic... The hub replacement looks somewhat straightforward, which are usually the jobs that turn into a bear.
  6. grnd0
    grnd0 Member
    42
    26
    Really easy job. Got the hub from Rock Auto. They have a bunch. Went cheap
    and got one for around $65.
  7. yortlecti
    40
    Toledo, OH
    WJB or Dur International?
    I considered picking up a cheap pair just to see if it fixes the problem, but I know if it DOES fix it that I'll wish I had spent a bit more so I'm not tearing in to it again in a year...
  8. grnd0
    grnd0 Member
    42
    26
    DUR. Quality is probably better than the original.
  9. yortlecti
    40
    Toledo, OH
    I just ordered a pair for the rear! Thanks so much for the feedback!
  10. yortlecti
    40
    Toledo, OH
    Just a quick update for those who may stumble across this thread: I installed the rear wheel hub on the passenger side today, and it literally made all the difference. My roaring lion is now a purring kitten. I went with the Dura International hubs from RockAuto.com, so not sure how long they'll hold up, but at least I know how to do this now and can always swap them for nicer hubs should these fail in a year.
    Just to note, my rear hub did not have the distinctive "wub wub" most folks reference for bearing failure. It was just an excessively loud roar coming from the rear end. Even when I got the hub off the car, it didn't make the notorious grinding sound every YouTube video teaches you to look for. But it was definitely the problem!
    I've spent the past several days researching this, and had to overcome a rotor that was rust-welded to a hub, and a hub that was rust-welded to a knuckle. I'd be happy to share what works (and what doesn't), should anyone need help.
    Thanks to all for their contribution!
    Lightning Racer likes this.
  11. Ethan Waldman
    Ethan Waldman Junior Member
    45
    Vermont
    Hi! I have a similar problem with my 2011 III, but drivers side front. I'm curious if you've been happy with the quality of the Dura-Go since installing it 6 months ago? I'm hoping to save some cash but don't want to install a hub that I'm going to need to replace again soon...
