Driving a Prius Prime
Discussion in 'Prime Main Forum (2017-2022)' started by randomwalk101, Apr 15, 2018.
  1. randomwalk101
    randomwalk101 DYI'er
    532
    269
    texas
    I know it's a Prius and of course, not "performance" focus...Anyways, on my 2017 Prius Prime Adv, it most of the gadgets but driving it, the car seems to "float" or "wonder" around a bit at high speed when going in a straight line. It doesn't seem like it's "planted" or inspire confident when driving it. Anyone else experiencing this?
    May be it needs some rigid collar to tighten up the sub-frame to the chassis or something...something like Spoon Sports rigid collar???
    49,511
    might be the tires, what pressures are you running?
  3. randomwalk101
    532
    269
    texas
    I think 40 psi? Little higher but that the same pressure I set with the 2016 Prius and it doesn’t have the problem as the Prime. May be is it because the Prime is heavier (bigger battery)?
    49,511
    i would think that would help? how about tire brand?
  5. randomwalk101
    532
    269
    texas
    Toyo nano entertains A29
  6. bisco
    49,511
    i have no experience with them, were the 2016's the same?
  7. Couldn't help but be amused at the title: you have a "Prime Prime"
    Which reminds me, did yours come with the "Advanced Advanced" package? :LOL:
  8. randomwalk101
    532
    269
    texas
    iPhone auto correct. It’s a bitch
  9. EyePrime
    EyePrime Active Member
    268
    115
    Ottawa, Ontario, Canada
    2018 Prius Prime
    No, don't have this problem. Are you in winter or spring tires. Is it hot and you have winter tires, If so then it will feel floaty. If its cold and you have all seasons or springs it will feel floaty.
  10. Lucifer
    Lucifer Senior Member
    1,014
    485
    Nh
    Turn off the lane departure warning, it floats you around, as you mentioned check the air pressure.
    Stop driving above the speed limit...
  11. Tideland Prius
    16,159
    The high tire pressure may be one reason. Try dropping it to 38 or 37 PSI.
    Is your 2016 a touring? Those have wider tires.
  12. benagi
    benagi Active Member
    525
    280
    Utah
    I had my first experience driving in heavy winds today going home from work on the freeway. My speed was around 60 mph. This Prime seems to need more driver input than my 2012 Prius v. Usually I try to keep the steering wheel in one position when being buffeted by the wind, but with the Prime I had to keep correcting just to keep the car in my lane. Anyone else noticed this?
  13. Tideland Prius
    16,159
    Well that's disappointing.
    I was hoping that would've been addressed (or at least reduced). Gen 2 and 3 Prii suffered from this too. (at least those with the 15" wheels)
  14. Blue-Adept
    Blue-Adept Active Member
    293
    179
    Grand Rapids, Michigan
    2018 Prius Prime
    The grooves in Concrete makes mine float at high speed.
  15. padroo
    padroo Senior Member
    2,763
    2,250
    My 2016 regular Prius does it too. I have the same tires and going straight I have to put a slight input with the steering wheel, kind of back and forth to keep it centered in the lane. On crooked roads there is no issue.
    I think it is the caster setting in the steering that causes it. My old 2008 did not do this.
  16. benagi
    525
    280
    Utah
    I played with the steering today on the way home from work. I noticed that when I turn the steering wheel left and right quickly (only minor left right motion) at about 50 mph, the car really didn’t move much to the left or right. Feels like a really loose front end. Don’t know if it could be tire size or something else. My Prius v has 17” tires and the Prime only has 15” tires. Will have to drive the “v” again and see if there is a lot of difference between the two. Will keep you posted.
  17. SteveMucc
    SteveMucc Active Member
    391
    268
    Kentucky
    Mine had a suspension piece in the rear that was not tightened sufficiently. Wore through enough to actually crack. My car drives much nicer now that it was replaced and properly tightened. If you start hearing any squeaking noise at all bring it in and have them check the suspension (on mine particularly it was the left rear upper control arm).
    BTW: I also suffer from high wind buffeting. Living in hilly farmland you can be completely shielded one second and then suddenly hit by 40MPH winds coming off a field. Usually I can tell when it's coming up by looking at semi's that suddenly swerve a foot to one side.
    westy72658 and benagi like this.
  18. fneil
    fneil Member
    71
    52
    Carrboro, NC
    See earlier threads about this. Many of us have complained about the lack of centering/road feel. I have tried dropping the tire pressures back down and it made little difference. Everyone in my family that's driven the car has commented on it. Not an issue around town, but on a long highway trip I find the constant attention required to keep it centered in the lane tiring. I do not have lane assist turned on.
    I have the Nano tires, and when they wear out I'll probably look for a different set that could help (some here have mentioned improved handling going to Michelins), and maybe I'll have my alignment guy see if he can tweak anything (though I understand not much is adjustable under there). In the meantime, I've more or less gotten used to it, so am letting it slide...
