Driving advice
Discussion in 'Gen 4 Prius Main Forum' started by bobusa, Sep 13, 2016.
  1. bobusa
    bobusa Member
    58
    Bellevue
    Hello All,
    Got my first Toyota and First Prius last Sunday. It's 2016 Prius Four with AT AND CONVENIENCE package.
    Now when I started driving it on the road I try to drive in Eco mode as much as possible to get good milage. And I also try not to go into PWR zone on the eco scale as much as possible. But this pissing off other drivers behind me as I accelerate very slow. How should I drive so that I can get good milage and not be honked or piss off others
    iPhone ?
  2. pakitt
    pakitt Senior Member
    2,173
    1,313
    Colorado
    Set it in normal mode and drive it.
    Be as fluid as possible and accelerate as progressively as possible, even landing in the PWR zone if so desired or needed. Let the Prius take care of the rest.
    When braking start very smoothly and then increase as much as necessary and safely.
    Try to glide as much as possible in traffic. Predict traffic lights and drivers' behavior to avoid sudden braking and accelerations.
    You will get amazing MPG by doing that.
    Key is driving as smoothly as possible. Not slowly like a grandma. That will not work and will be dangerous and annoying to other drivers as you describe.
    When you have done a few months of that, you can try to move to ECO mode to see what happens on your routes and driving habits, or follow the ECO drive assistant (the blue bar underlying the HSI that shows how much you can accelerate).
    plug-it-in, RCO and alanclarkeau like this.
  3. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Generally - best to accelerate more normally - it won't make a huge difference to your mileage - keep the gentle acceleration to when there's nobody behind when you can maybe crib a little more. Acceleration - you've got to get up to the speed anyway, there are a couple of on-ramp situations near me where it's much safer to floor the throttle for as long as it takes to merge with the traffic, then ease back with the traffic flow.
    Staying in ECO mode doesn't seem to make much/any difference to mileage in most driving circumstances either - what it mostly does do is moderate the accelerator pedal so you have to work it harder. I started first tank with ECO, next NORMAL, now PWR - and I'm getting better mileage with PWR, but that could be because I'm getting used to the car. ECO does alter the A/C setting though, but if it's hot, you may not want it to do that anyway.
    One of the best tips is, if you're not in a hurry, get in the "slow lane" (if Bellevue is in USA, I think that's the RH lane) and keep up to the slower traffic, rather than keeping up to the fast traffic in the fast lane. Speed does make an appreciable difference to your mileage.
    Just enjoy driving it - you'll still get good mileage. In time, you'll learn tricks and improve a little bit more.
    RCO likes this.
  4. krmcg
    2,592
    2,393
    Whittier, CA
    I am that slow Prius driver. But, I try very hard to be courteous. I stay to the right, but keep up with traffic. But at the same time, I try to find a nice slow truck to follow on the freeway.
  5. Mendel Leisk
    42,352
    As far as impatient/aggressive/irrational drivers you contend with:
    1. Stay right as much as possible.
    2. Get behind trucks/buses.
    3. Keep your cool.
    4. When someone insists on aggressive/persistant tailgating, and won't quit: try the hazards, just leave 'em on, and gradually increase your following distance to the vehicle ahead (if applicable). If and when safely possible: "reverse pass" them, ie, switch to the left lane, slow down and let them by. If extreme and persistant (and there's no lane change possible), pull over and park, let them by. If it seems warranted, record their plate and report them. Chances are they have a slew of infractions, this might help get them off the road. Do NOT lose your temper, grandstand, gesture.
    To improve mpg:
    1. Obey the speed limits.
    2. Keep a generous space in front, watch for pending slowdowns, and use that space instead of your brakes.
    3. Accelerate gently: on level roads aim to keep the Hybrid Synergy Display bar between 1/2 and 3/4, with short jabs higher just as needed.
    Road manners:
    1. Come to full stops at broad white line, at stop signs.
    2. Be courteous/cognisant with other motorists, bicyclists and pedestrians.
    3. Always signal.
    #5 Mendel Leisk, Sep 13, 2016
    HobbsNick, 'LectroFuel, RCO and 3 others like this.
  6. krmcg
    2,592
    2,393
    Whittier, CA
    Great advice!
  7. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    You guys know I'm gonna chime in here. And you know the "Rebel" in me is gonna come out. :D
    Except for the very first tank, I've been driving my Prius like a regular, normal car. All those things are good advice, if you enjoy "thinking" about that your driving a Hybrid, and you enjoy concentrating on all those gauges, and dancing lines, and graphs, and numbers, etc.
    For me, I find it all those screens too distracting. And you don't want a distracted old dude in the car behind you! :LOL:
    So I'm just driving normally; not speeding around. Just going with the flow, but also not trying to achieve the *ultimate* highest gas mileage. I like the smooth, easy, unrestricted feel of the PWR mode, and that's what I use full-time. My current tank of gas, after 440 miles of city driving, the display shows I'm getting 66.1 MPG... and I'm not even trying. :)
  8. krmcg
    2,592
    2,393
    Whittier, CA
    Choices, we all have choices My current tank is at 770 miles and displays a readout of 78.5 MPG. It's worth it to me to drive in ECO and drive slow. I am trying to reach the elusive 80 MPG displayed for a full 800 mile tank.
    #8 krmcg, Sep 13, 2016
  9. DonDNH
    DonDNH Senior Member
    1,711
    655
    Nashua, NH
    Four Touring
    What everyone else above has said and set your tire pressure a tad higher. Many here use Front=40 and Rear=38 and achieve very good mileage.
  10. Coast Cruiser
    2,267
    2,571
    78.5??!
    I would miss going to gas stations! I can't go that long without getting my 1/4 lb "spicy dog" and cold drink.
    I actually didn't buy a Prius because of the gas mileage. I bought it because the driver's door fell off my Camry! :ROFLMAO:
    (My "other car" is a Ford F350 Heavy Duty Crew Cab 4X4.)
  11. Mendel Leisk
    42,352
    Try a tank with Normal, keep everything else the same? That said, I've read that pedal travel in ECO with the 2016 is roughly comparable to Normal in 3rd gen. ECO in third gen makes pushing the gas pedal a laborious chore.
  12. krmcg
    2,592
    2,393
    Whittier, CA
    I tried an entire tank at PWR per the Coast Cruiser request. I got 73.9 displayed and 70.3 calculated. I didn't like the "jumpy" and "touchy" feel of the gas pedal, but after a couple of hundred miles I grew used to it and honestly could not tell the difference. I went back to ECO because I like the way it manages the cruise control "catch up" feature better.
    RCO and Mendel Leisk like this.
  13. Mendel Leisk
    42,352
    Yeah I never use PWR, just Normal. But again, there's apples/oranges going on here: 3rd gen ECO pedal travel was really long, Normal is very linear, feels, well: normal.
    krmcg likes this.
  14. Coast Cruiser
    2,267
    2,571
    For those newer owners who are looking for advice/instructions on achieving the best gas mileage, Kevin is the MAN! Outstanding record of great long-term results.
    krmcg likes this.
  15. krmcg
    2,592
    2,393
    Whittier, CA
    I'll buy you a burger sometime for all of the compliments. But no, you can't put your trash in my trashcan
    alanclarkeau and Coast Cruiser like this.
  16. Kramah313
    Kramah313 Active Member
    411
    326
    Dallas, TX
    The Prius has a small and very efficient engine - I have found that acceleration rate (as long as you aren't flooring it) doesn't matter nearly as much to MPG as braking rate does. The more you can glide or coast to a stop instead of jamming on the brakes (especially the friction brakes - if you fill up the CHG bar) the more you can really improve the mpg.
    Disclaimer: I have a gen 3 and I'm no hypermiler. But I would suspect the gen 4 is much the same.
    Coast Cruiser and fuzzy1 like this.
  17. grape808
    grape808 Active Member
    150
    153
    Hawaii
    I just got my first Pri 2 weeks ago and I'm getting about 55 mpg average from the time I got it. Averaging higher on my longer commutes at 60 to high 70s mpg. I'm still speeding 10 mph over the limit (hypothetically of course).
    I say drive normal and make your adjustments in other ways, such as those given in the newbie advice thread about accelerating quickly and then pulsing. Learning those beginner tips dramatically increased my averages during my first days.
    Coast Cruiser likes this.
  18. bobusa
    bobusa Member
    58
    Bellevue
    Can I go to regular gas station air pump to check and fill the air or there is something special I need. I remember reading about nitrogen or something
    iPhone ?
  19. krmcg
    2,592
    2,393
    Whittier, CA
    Any air is good air
  20. bobusa
    bobusa Member
    58
    Bellevue
    All great advices. Thanks. I did drive on Normal mode today and it was bit better. I will follow all of yours advice and report back.
    iPhone ?
    Kramah313 and krmcg like this.
