Driving, can't see because of either sun or headlights...
Discussion in 'Fred's House of Pancakes' started by Higgins909, Dec 31, 2018.
  1. Higgins909
    Higgins909 Member
    277
    67
    Night time driving is a bit of a headache and at points though out the day, the sun can have a glare. The sun is so bright that I could have glasses on and the visor flipped down and it does just about nothing to improve visibility. Night time driving it's like everyone has their brights on or something. There are times on a long straight the car's lights about 2 miles away will bother me more then the car with it's lights about 200 ft in front. My neighborhood is on a 55mph 2 lane (1 each way) that can be busy at times. I can only see something like 50ft in front of me at times.
    What do you think?
    Higgins909
  2. audiodave
    audiodave Active Member
    798
    269
    US
  3. kenoarto
    kenoarto Senior Member
    398
    Chicago, IL
    This is not a Prius problem. Have you had eye surgery?
    jerrymildred and audiodave like this.
  4. fuzzy1
    10,335
    ... unless the windshield is not adequately cleaned occaisionally, including inside.
    But there is nothing different between the Prius and other cars regarding this.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,137
    Tampa, FL
    Scratches or gunk on the windshield, scratches on your eyeglasses, or cataracts. If it's not the first two, do you get regular eye checkups? Glare and starburst effects on small, bright lights are a symptom of cataracts.
  6. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,799
    2017 Prius c
    I also recommend seeing an eye doctor.
    You might have "glare blindness".......in addition to the other things mentioned.
    audiodave likes this.
  7. bisco
    51,155
    dry eye, try some tears or refresh
  8. jerrymildred
    11,517
    14,137
    Tampa, FL
    I have dry eye pretty badly. It's not like what @Higgins909 described. My dry eye doesn't affect brightness and it happens any time of the day. Oddly, I rarely get symptoms when driving, probably because I blink plenty when driving. But I often get it when working all day on the computer or when watching a movie on the TV.
  9. Mark57
    2,945
    2,738
    OK
    You "could" have the beginnings of cataracts. Your description sounds exactly like the symptoms. They're very easy to fix now. Walk in, walk out.
    jerrymildred likes this.
  10. Mendel Leisk
    40,586
    @Higgins909 what is your optometric situation, are you say short sighted (myopic), long sighted, have astigmatism, or? Wearing glasses with corrective lens, contacts?
  11. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,800
    Undisclosed Location
    Hmm...
    It certainly could be symptoms of cataracts or early cataracts....
    But I would ask, does this glare happen all the time?
    Do you notice these symptoms ONLY behind the wheel?
    If this glare is eye related, I would expect that you would have these symptoms in other situations with similar light and visual feedback.
    In any case, yes, I would get my eyes checked...FIRST. Knowing what condition your eyes are in is very important.
    Once you know that status, you can correctly start to assess the best approach or answer.
    Eye exams are generally cheap and IMO very important.
    PS.
    I would strongly urge you pursue this ASAP. Your description of your personal visual driving condition sounds dangerous.
  12. Mendel Leisk
    40,586
    Kinda makes me think of when the optometrist puts in the belladonna drops for a look-see: for the next few hours bright lights are tough. And good luck if you need to do some fine close-up work, lol.
    All of this is due to pupils over-delated, not constricting with bright light.
  13. bisco
    51,155
    how old are you? have you tried the walmart old man sunglasses?
    kenoarto likes this.
  14. kenoarto
    398
    Chicago, IL
    Or cool guy, glacier glasses (the ones that block the light coming from the sides)!
  15. Mendel Leisk
    40,586
    He's 22.
  16. bisco
    51,155
    that's a problem
  17. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    Are you headlights glass (plastic) clear or foggy clean them with mother's aluminum polish paste with a drill pad. Best way I know and then repaint with plastic clear paint or a UV blocking wax.
    And if you have halogen bulbs I would definitely switch to LED 6500k range which is white. And they don't have a white spot like normal headlights to everything's just brighter so when you drive through the fog you don't see a reflection of your headlights there cheaper one but I do recommend that power supply outside of the bulb or my first choice the heatsinks that metal strips coming out of them. No fans in the light it is a Prius so you don't want to hear them I use the ones with the heat sinks but I've used both the noise didn't bother me Screenshot_20190102-051712_Amazon%20Shopping.jpeg 1546435357532.jpeg
  18. bisco
    51,155
    wouldn't a good pair of sunglasses be easier?
  19. jerrymildred
    11,517
    14,137
    Tampa, FL
    Symptoms:
    1 Glare at night from other cars headlights.
    2 Glare from the sun in the daytime.
    Recent suggestions:
    1 New headlights.
    2. Sunglasses
    I can't see how either suggestion helps with symptom #1 or how sunglasses help with symptom #1.
    Eye doctor.
    Mark57, fuzzy1 and bisco like this.
  20. bisco
    51,155
    i wish high well, i've had eye problems, and it's no fun :unsure:
