Driving Down a Mountain
Discussion in 'Gen 2 Prius Main Forum' started by Aaron, Jul 12, 2011.
  1. Tideland Prius
    16,683
    It's the equivalent of downshift in a regular manual or automatic transmission equipped car. You could use it down the entire mountain but it's preferred that you gain some of that momentum via regenerative braking and use the brake pedal to slow the car now. After the battery reaches full charge, you can continue to ride the brake pads or use B to assist in slowing the vehicle so that the brake pads don't overheat.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,082
    Northern Michigan
    Adding to Tideland's comments, some people also like the sense of control in B mode. On a long mountain downhill you often find yourself switching back and forth from gas to brakes. With B mode you can often stay on the gas, easing up to go slower, pressing down to go faster. It makes for less of a dance.
    Tom
  3. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    On a long descent, your friction brakes could overheat, losing effectiveness. This would be bad.
    By using B mode from the summit, you use less friction brakes and more 'engine as an air pump' brakes. This can keep your friction brakes cooler, and you out of the runaway truck ramps.
    http://www.oregon.gov/ODOT/MCT/docs/EmigrantHill.pdf?ga=t
    As I read this, 59% of the accidents on Emigrant Hill result from brake issues. I have watched a truck use an escape ramp, it moves a LOT of gravel!
  4. SpikeVFR
    SpikeVFR New Member
    221
    SF Bay area, CA
    why would you think that? Where did you read that?
  5. SpikeVFR
    SpikeVFR New Member
    221
    SF Bay area, CA
  6. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Brakes are for changing speed, engine braking by gearing down, or B mode in the case of a Prius, are for maintaining speed.
    The heat generated by the brakes on a long steep descent isn't good for the brake system and in some extremes cases can cause brake failure.
