Driving in B Mode
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by bestmapman, Jul 25, 2021.
  1. bestmapman
    bestmapman 04, 07 ,08, 09, 10, 16, 21 Prime
    1,289
    242
    Kentucky near Cincinnati, OH
    I have been reading a lot about the Chevy bolt and it has one pedal driving I was wondering if anyone here uses our B Mode as a poor man’s one pedal drive.
  2. Leadfoot J. McCoalroller
    8,278
    7,784
    Pennsylvania
    2018 Prius c
    Right here on priuschat I've read about at least one other person doing that.
    Keep in mind that decelerating in B mode never illuminates the stop lamps on the back of the car.
    52,804
    i don't, but i drive so slow, and leave so much room between me and the car in front, that normal regen is usually enough except when coming to a stop.
  4. ChapmanF
    18,988
    When I am on a route where one-pedal-ish driving would be convenient, sometimes I do it in D by setting the cruise control at its lowest (25 mph) setting, then using the go pedal to drive faster.
    The one thing that has to be remembered is it stops being one-pedal-ish once the speed drops to 25. :)
    Also, any use of the brake while cruise is on has two effects. First, as all know, it cancels the cruise setting. Second, the car always interprets it as exigent, and goes straight to four-wheel hydraulic braking, skipping any further regen for that braking event. That ends up being ok with me, because often when I am doing that style of driving, it is on a curvy road, and I don't mind having four-wheel control one pedal touch away.
    To make a non-exigent brake event, can just pull the cruise stalk to cancel, then brake.
