Driving on a spare tire
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by mridul, Nov 11, 2011.
  1. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    About 18.5mm smaller in OD by my calculations, on the Gen 4 with 17" wheels.
    Standard wheel: 215/45/17
    Skinny spare: 125/70/17.
    With 60 p.s.i. pressure in it, might it take up that extra difference and ride higher though ?
    FuelMiser likes this.
  2. Mendel Leisk
    42,259
    That's different than our 3rd gen 2010 Prius then. I've placed a regular wheel/tire flat on a slab, stacked the temp spare carefully aligned on top, and checking with a carpenter's square set on the slab and pushed against the tread: there was at most 1/8" difference.
    Addendum:
    Looked up the Prius c tire sizes in the 2012 Owner's Manual:
    And then feeding the above info into a calculator here:
    Speedometer Calibration
    there is some difference, about 4.5% reduction, going from OEM to spare:
    I tried the same exercise with our 2010. The two tire sizes, from the Owner's Manual:
    With the stock 15" tire, going to the spare the difference is around 2%:
    We have the 17", which has slightly smaller OD, and there the difference is negligible:
    Interesting exercise. Summing up, our case (3rd gen with 17" rims) there's only 0.5% reduction, with stock 15" tires reduction would be 2%, and the Prius c though, the reduction is 4.5%.
    #22 Mendel Leisk, Aug 7, 2018
    Patrick Wong and dubit like this.
  3. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    There is something in my Owner’s Manual.
