Driving on bad hybrid battery
Discussion in 'Gen 3 Prius Main Forum' started by Keepdriving, May 23, 2018.
  1. DLC82SV
    DLC82SV Member
    241
    119
    Will I not be able to clear the codes and get my car out of limp mode just like the OP has been doing via OBDII via my MFD when the time comes?
  2. DLC82SV
    DLC82SV Member
    241
    119
    Also, can anyone tell me what my old codes mean before I clear them? They are in the picture I attached.
  3. wjtracy
    wjtracy Senior Member
    11,374
    3,609
    Northern VA (NoVA)
    I think @uart down in OZ milked a weak Gen2 HV Batt for quite a few years.
  4. JC91006
    16,936
    8,647
    There are no meaning to those codes, you need to read them via OBD reader.
    DLC82SV likes this.
  5. DLC82SV
    DLC82SV Member
    241
    119
    Thanks
  6. Keepdriving
    Keepdriving Junior Member
    35
    27
    Palatine
    Hit 218K yesterday. Went to Louisville and back about 650 miles. No problem with the battery. Again, seems like after a long road trip, the battery seems to hold the charge longer.
  7. Buderim
    Buderim Junior Member
    28
    Queensland Australia
    i-Tech
    This would be a good challenge for Hybrid Automotive , they should loan you a Prolong setup and see if it can fix your battery .....
    DLC82SV likes this.
  8. Keepdriving
    35
    27
    Palatine
    I’ll probably fry what good remaining cells I have left in my battery. Probably better for me to drive out to California and back to fully recondition the battery.
  9. njasmina
    njasmina New Member
    Austin, TX
    Found this thread end hoping someone can help me with some info.
    I have a 2010 prius with 150k miles on it. Earlier this year my cousin borrowed my car, ran it out of gas which then caused the hybrid warning lights to come on and the car wouldn’t start again even after gas. Found out through here that it was a common thing and then had to pay dealer to reset codes for it to start.
    Now I got some warning lights yesterday. Took the car to autozone to have them read the codes for me and was told it says replace hybrid battery. Car drove fine back home and drove me 20 miles to work this morning as well, but the triangle light is still there with the warning saying to check hybrid system.
    Is my battery really bad if it’s still driving normal and hasn’t actually required a reset?
    Also, if I were to choose like OP to just try to run this battery as far as it’ll take me, how would I keep resetting the codes if it (I’m assuming) shuts off and won’t let me drive until it’s reset?
    Please forgive me as I’m not privy at all with this kind of stuff and probably even butchered the question. I appreciate the help!
    DLC82SV likes this.
  10. JimboPalmer
    12,470
    6,879
    Greenwood MS USA
    1) a 'hybrid specific' code reader can often tell which cell in the battery is having difficulty. Cells can be balanced or replaced cheaper than the entire battery. Most code readers only read engine codes, a Prius has at least 5 computers all sending different codes. If you have an honest dealer or hybrid mechanic, it may be worth while to have them diagnose it.
    2) Resetting the codes is as easy as removing the cables to the 12 volt battery. If there is something wrong, they will be back shortly.
    3) as mentioned in 1), now it may be fixable, while if you let it run with one cell not helping, the entire battery may be at risk.
    Best Hybrid Repair in Austin, TX - Last Updated October 2018 - Yelp
    njasmina, DLC82SV and Raytheeagle like this.
  11. sue07
    sue07 New Member
    Thank you so much for this thread! This has been extremely helpful!
    So, what is the OBD2 reader that you are using to reset the code? (or better yet, what do you recommend for Gen 3 Prius?)
    Thank you! what did you end up doing with your car, keepdriving?
  12. Zombee77
    Zombee77 New Member
    Arkansas
    Does anyone know the outcome lol....was very interested in hearing what happened
  13. Sonic_TH
    Sonic_TH Active Member
    575
    96
    Puerto Rico
    2016 Prius c
    Any updates on this?
