Driving the 2010 Prius in severe winters?
Discussion in 'Gen 3 Prius Main Forum' started by Indyking, Jun 9, 2009.
  1. Indyking
    Indyking Happy Hyundai owner...
    1,280
    I don't know... Indy, Chicago, Madison (WI)... it
    Re: Driving the 2010 Prius in sever winters?
    Great comment! I really like my CR-V and it comes as no surprise to me that it is currently holding more value than any other Honda (according to Honda itself), but I have to admit that, based on my 3 Prius test drives (including a long stretch), the Prius cabin feels more comfortable for long hwy drives (I’m going to drive 800 hwy miles/week). The Prius is a lot quieter. The one thing Honda still struggles with in the CR-V is road/wind noise. My only concern about changing from the CR-V to the Prius is driving in severe winters but other people here showed evidence that it won't be that much worst than the CR-V…
  2. cellogail
    cellogail Junior Member
    22
    Michigan
    Three Touring
    Hi. I purchased my 2010 Prius II in May and was getting between 50-52 mpg. However, this winter, I am only getting about 41 mpg. This is a LOT worse than the mileage I got in my 2008--relatively speaking. (Our daughter is now driving that car.) Can anyone tell me whether this is normal? My driving habits haven't changed in any significant way.
  3. captnslur
    captnslur Junior Member
    78
    Lake Crystal, Minn
    Indyking....We too, have a CR-V which is actually a front driver untill the wheels slip a bit when the rear wheels kick in, and an '06 Prius. Frankly, the Honda is better in unplowed parking lots, but we'd much rather use the Prius on slippery snow packed winter roads. We put some Michelin T-ICE snows all around on the Prius and it will easily out perform the Honda in everything except the unplowed parking lot. Sure it is faster across the intersection, but once up to speed the Honda is a handfull compared to the snow tire equiped Prius. As for the mileage hit, we get in the low 40's while the Honda mileage sinks to the mid to low 20's. And, the Prius "starts" easily is sub zero weather while the Honda grinds hard to get started.
  4. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Insufficient info. Decline in mileage is expect in all cars due to cold weather. Please start a new thread w/answers to http://priuschat.com/forums/gen-iii...-answer-these-questions-esp-if-youre-new.html.
    What did you get in your 08 in comparable weather conditions to what you're facing now?
  5. Daddy Dave
    Daddy Dave Member
    94
    39
    Sheridan, WY
    My 2010 is averaging around 38 mpg this winter in northern Wyoming. It will be -23F tonight with a high temp forecast of 1F. 14k miles on the car. It is the best cold weather car I've ever owned!
  6. bisco
    52,889
    i believe indyking has been deposed.:(
  7. nickfromny
    nickfromny Member since 2007
    309
    24
    Binghamton, NY
    No snow tires = no go. Due to Electric motor, ABS. VSC you can not spin the wheels to get out of a jam. Spinning the wheels will fry the Electric motor. With snows, car goes well in up to 6 inches of fresh snow, then it gets stuck. Get engine block heater and it will start in coldest Upstate NY winters.(-30) no issues. Car will snap oversteer once those rear batteries & your luggage get rotating. Try to keep all of your heavy gear infront of rear axle. Worst MPG in 60mph headwind with a ski box on top was 38mpg. Getting a third Prii this June. Can't beat the MPG.
  8. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Not that the "new" questions aren't valid, but yes, check the dates of the posts. I believe Indyking has long since ICE'd his way into the sunset in a Hyundai Sonata...
  9. Skoorbmax
    Skoorbmax Senior Member
    2,641
    265
    Western NY
    We did about 40 on the nose on our last tank in the winter here in Western NY, so it's a good 7-8 below summer numbers, but we've had a tank as low as 38. I think the car is just fine in snow. The reality is if you're trying to get through heavy packed snow no two wheel drive car is great, but for what we encounter here, ice, snow in storms, etc. the car does well. We are using all-seasons. May go winter at some point. Traction control and stability make this more than capable.
    Remember, the vast majority of people do not have 4wd cars in climates like yours and they manage to make it.
  10. cossie1600
    cossie1600 Active Member
    903
    94
    CT
    Things will get better once you get snow tires, but the car is still one of the worst car I have had in the winter. The traction control is so sensitive that it can put you in a lot of uncompromising position, occasionally it would leave you stuck too. You just have to drive smart and unavoid spots where you would get trapped.
    My indicator shows 18.4mpg on a 12mph average speed.
  11. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Words of wisdom... except avoid, not unavoid.
  12. cossie1600
    903
    94
    CT
    type too fast on the phone sorry, you are right
  13. cycle11111
    cycle11111 New Member
    145
    McKinney, Texas
    I don't know what you do but that does not apply. Here yesterday and today in Texas we are covered in 1 inch of ice everywhere - not an overstatement. My wife can barely move her 4 wheel drive Merc and a friends Infiniti is stuck down the the hill which I just drove up in the Prius. Simple rule when the Trac light comes on back off on the accelerator until it goes out and slowly move forward. I love this car in the snow and as long as it is not over 5/6 inches it is great.
  14. qbee42
    qbee42 My other car is a boat
    18,058
    3,082
    Northern Michigan
    I assume you mean five or six inches, not 5/6th of an inch.
    Tom
  15. cossie1600
    903
    94
    CT
    Let's just say we have a different expectation on what a car should do in the winter time.
  16. RichTheHippie
    RichTheHippie New Member
    Maine
    nyone have a good recommendation foe studded snow tires? I'm in Maine and go around 7K in the snow season
  17. Zhe Wiz
    Zhe Wiz Member
    128
    Ithaca, NY
    I'd go with General Altimax Arctics. They'll kill your gas mileage, I expect, but they are EXCELLENT even unstudded on my Subaru. I'd give them the edge over Blizzaks in slushy wet and packed snow. Can't say much about ice, but with studs they'd certainly win that battle too.
    Zhe Wiz
  18. RichTheHippie
    Maine
    Thanks I'll check 'em out
