Driving with cruise control
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by bilbo04096, Jan 23, 2014.
  1. bilbo04096
    bilbo04096 Member
    136
    26
    Yarmouth, Maine
    2013 Prius Plug-in
    I have done a few experimental commutes to try to get a sense as to whether using cruise control on the interstate offers a greater degree of fuel efficiency than trying to maximize efficiency with my own efforts. I should mention that I keep the car in ECO mode continuously and don't use EV-boost on the highway. I get the impression that the CPU directing cruise control indeed does a better job than I can, although it is difficult right now to make a good determination due to the very cold conditions here right now, which are obviously affecting both EV and gas engine efficiency. I'm curious to know if anyone in a more benign environment has taken a look at this and has some insight to offer one way or the other.
  2. RooRocks
    RooRocks Junior Member
    2014 Prius Plug-in
    I live in Southern California and my commute is not flat. I wish the cruise control had more 'brains' and didn't go full throttle on a slight incline. If going 72mph I'd be fine dropping to 70mph on the incline with steady throttle pressure but instead the car just floors it.
  3. bilbo04096
    bilbo04096 Member
    136
    26
    Yarmouth, Maine
    2013 Prius Plug-in
    Is it flooring it with ECO mode on or off?
  4. RooRocks
    2014 Prius Plug-in
    I always have eco mode on.
  5. Mendel Leisk
    42,343
    I'm not sure if this is a plug-in specific question. Anyway: I drive in normal mode (neither ECO or Power), and use cruise quite a bit. Watching the instant mpg on a ScanGauge I've found it does pretty good at driving efficiently. The only thing: at low speeds around town it'll stay in stealth mode as long as possible, maybe too long for my taste, eating up the (meager, non-plug in) charge happily.
  6. El Dobro
    El Dobro A Member
    7,106
    3,282
    For me, CC saves on fuel and speeding tickets. ;)
  7. bisco
    52,848
    if you work at it, you can do much better than cc. if you don't, throw it in cc.;)
    CaliforniaBear likes this.
  8. markabele
    5,084
    1,782
    Nebraska
    Ya, you can do better than the Gen3 cc. This is one thing I hope they'll address in the next gen.
    Side note...dynamic radar cc following (drafting) a truck that slows down up hills and speeds up going down is ideal. Wish I had it! :) Haven't done the math, but I guesstimate it could save you a couple hundred bucks over the life of the car if you drove hilly interstates a lot.
  9. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)I prefer cruise control on the interstate.
  10. markabele
    5,084
    1,782
    Nebraska
    Totally agree. I use it, too. But from a pure numbers standpoint...you can do better.
    Also, if it interests anyone. I've used a modified DWL technique that takes much less work and still uses CC.
  11. bilbo04096
    bilbo04096 Member
    136
    26
    Yarmouth, Maine
    2013 Prius Plug-in
    markabele, would you please explain "DWL technique" a bit more? Also, is it to our advantage to use cruise in ECO mode when just humming along on the interstate. I began this thread wondering if others found that to be the case. It is being difficult for me to determine since the current frigid mornings really take a toll on mpgs. The "slightly warmer" evening commutes in reverse are consistently being better. I just don't know if it's best to keep ECO on when cruise is on at highway speeds.
  12. Jerry Liebler
    Jerry Liebler Member
    177
    85
    Science Hill Kentucky
    2013 Prius Plug-in
    My limited observations suggest that ECO mode allows a bit more variation in speeds, or stated another way the "throttle" response is 'softer'. I now use ECO almost always. I often drive on rather hilly roads with 55 mph speed limits (rural Kentucky). While I use cruise I don't set it and forget it, instead I use tap up and tap down to modulate my speed, based on the instant MPG display. I aim for a peak speed (at the bottom of a large hill) of 60 and a minimum speed (at the crest of a big hill) of 50.
    giora likes this.
  13. pmike
    pmike Member
    237
    81
    Central Florida
    We also have a 2012 Honda Civic (non-Hybrid) and with the ECON button on it will allow the car to bleed off almost 5mph before accelerating. We live in Florida and this is great for bridges. It will bleed off 4-5mph and pick it up on the decline. Picked up a 2013 Prius tonight. The trip was from the east coast of Florida to the west coast of Florida and back via highways. Both the Civic and Prius got 45mpg on this route. I feel the Honda cruise control is a little more intelligent/green.
  14. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    Hey, with two speeding tickets last year?
    I'm using a carefully set cruise control a LOT more now.
    Just saves me from potentially momentarily zoning out and accidentally getting a devastating 3rd ticket.
    Not scientific, but before this, I always felt that usually if I was paying attention, I could do better than the cruise control as far as fuel economy. Just because if I'm controlling the throttle, I can let the speed drop given momentum and conditions and what I see ahead on the road, to try to maintain good fuel economy. While if the cruise control is engaged, it's primary operation is simply going to be to maintain exact set speed.
  15. bilbo04096
    bilbo04096 Member
    136
    26
    Yarmouth, Maine
    2013 Prius Plug-in
    Right, but what I'd like to know is if the computer in the PiP is smarter/faster than we are in terms of rapidly modulating both gas and electric drive units optimally, based upon the road conditions at a certain speed. As RooRocks noted, the one advantage to not using cruise is that we can opt for letting the car slow as we ascend an incline, easing the demand for either fuel, whereas the cruise will keep speed constant and thus require more of each fuel on the upslopes. But for steady highway speeds of some duration in cruise mode I'd like to know if we'll see better mileage with ECO on or off.
  16. El Dobro
    El Dobro A Member
    7,106
    3,282
    I would imagine with the CC on, the system overrides the feel of the pedal, so Eco would only affect the HVAC system.
  17. bilbo04096
    bilbo04096 Member
    136
    26
    Yarmouth, Maine
    2013 Prius Plug-in
    It is my impression that ECO affects the hvac with the ultimate goal of achieving fuel efficiency. So, is it possible to say that the system will operate more efficiently than we, who just rely upon pedal feel? And what about with ECO off? I'm hearing the long term owners say that their experience seems to allow them to outperform the system when in cruise. I guess what I'm getting at is that perhaps we underestimate the program "smarts" and computing speed of the system since it has supposedly been designed to optimize fuel efficiency. Does this optimization include driving in cruise mode? And on the highway, does such optimization function better with ECO on or off? I know, a lot of questions, maybe better answered by the original Prius designers than by us.
  18. The Electric Me
    9,083
    5,801
    Well I think the simple answer would be YES the computer is faster than us in terms of modulating the gas and electric drives optimally.
    But, dynamic radar cruise control aside, cruise control cannot and will not know what is coming up ahead and will not make the possible human decision to cut speed to maintain fuel efficiency.
    I will admit my "opinion" is totally unscientific. I just always felt on long highway drives, I could do marginally better myself compared to having the cruise control engaged. This would be in the freeway or highway environments that might still be congested enough to see changes in speed. Urban freeway environments.
    On miles and miles of totally open freeway? I'll just set the cruise control...to give my foot a break. And I don't think there is much if any difference between the Cruise Control maintaining 55 mph and myself maintaining 55 mph.
  19. Lourun
    Lourun Member
    289
    35
    Glen Rock NJ
    2013 Prius Plug-in
    Freeway and 55 mph you either travel in the right lane or live in the sticks. Going that slow here will get you, run off the road! I use CC all the time and don't worry about if I can get a couple of mpg better manually, I doubt I can!
  20. drysider
    drysider Active Member
    823
    336
    Liberty Lake WA
    Out here, the freeways are rarely level for more than a few miles. Lots of up and down, and once in awhile a mountain pass. I can get about 10% better mileage not using CC....about 5mpg better.
