DRL bulb size? possible upgrades?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by KeepitSimple, May 30, 2014.
  1. KeepitSimple
    KeepitSimple Member
    128
    Washington, District of Columbia
    Searched. Couldn't find anything.
    2013 Prius ii
    #1 KeepitSimple, May 30, 2014
  2. xliderider
    xliderider Senior Member
    8,056
    3,223
    Honolulu, HI
    Can't see what year/model Prius you have since the update. If you are talking about the LED DRLs on the newer Prii, they are not removable/changeable, unless you get aftermarket DRL kits like the Philips Daylight 8 or 4 (Link, Link 2).
  3. KeepitSimple
    KeepitSimple Member
    128
    Would you install these behind the current, clear plastic housing? Or would one remove those triangular lights and replace with the ones you referenced?
    If one of those DRL goes out do you have to replace the entire unit?
  4. xliderider
    8,056
    3,223
    Honolulu, HI
    The Philips lights go in the lower grill or under the bumper.
    They have a warranty, the entire unit would be replaced if one LED failed.
    SCH-I535
  5. pauerbach
    pauerbach Member
    101
    34
    The DRL's on 2012+ models are comprised of a custom-designed LED array located just below your front turn signals in the bumper. They're not user replaceable.
    KeepitSimple likes this.
