DRL not working / Not installed / Safety Issue
Discussion in 'Prius v Main Forum' started by Dellrc, Dec 2, 2013.
  1. Dellrc
    Dellrc New Member
    2013 Prius v wagon
    We recently purchased a new 2013 Prius V with the preferred equipment package (LED lights, leather, etc) and noticed that there is no daytime running lights. We checked the manual and found 4 separate turn signal/ headlight control switches. The one installed in our vehicle is the "US version" and all attempts to have the DRL come on proved futile.
    I could not find anywhere in the manual a reference that would say "the DRL feature is not available in US designated vehicles".
    I took the vehicle to the dealer and he said that the vehicle was not equipped with DRL! The 2004 Corolla which was traded in had them but a new, upgrade 2013 vehicle does not?
    I called Toyota directly and they stated that the lights were not installed in this vehicle based on the VIN number. If the vehicle was intended for delivery in Canada they would have connected this feature. There is nothing that they can do at this point. If aftermarket DRL headlamps are installed "it could void the warranty".
    The lack of DRL in the US version of the Prius V is definitely a safety issue and a major step backward.
    I would like others with the same problem to follow this thread and consider the possible involvement of the NTSB to look at this problem.
  2. mikefocke
    3,700
    1,645
    Sanford, NC
    Why would an older Corolla have DRL and a newer Prius not have it? Maybe weight and current draw which both affect mileage? Maybe cost?
    I'd like it too but I can't complain about something that wasn't on the car when I bought it, I had a chance to look for it and didn't.
    Until the NTSB mandates DRLs like Canada does, doubt they would care.
    I know at least one of the Toyota US distributors makes an add on DRL kit, and I've seen the .pdf referenced here with installation instructions. Lots of DIY approaches have been posted here too. Search is your friend.
  3. rdgrimes
    rdgrimes Senior Member
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    The 2014 model has them. (FWIW)
    There's no way to "enable" DRL on the 2012-2013, critical parts are absent. So you can scream all you like, it'll never have them unless you install an aftermarket kit.
  4. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    You can get a DRL module from eBay that will enable your highbeams at 30% to be used as DRLs, just like they do in Canada. Link to the thread is in my signature below, link to the eBay auction is in the first post of the thread.
    As far as this or any other modification voiding any warranties, the dealer or manufacturer would have to prove that the aftermarket part or modification caused any problems. It's in the Magnusson-Moss act, or something like that.
    SCH-I535
  5. Dellrc
    Dellrc New Member
    2013 Prius v wagon
    Thanks for the help....but current draw would be less on the 13 Prius since they are LED. Seems strange that a company such as Toyota would go backwards with design and safety features. I have seen other posts with owners having the same problem. They also were never informed that there may not be DRL in their vehicles.
  6. Bingee
    Bingee Member
    210
    62
    Michigan
    Why toyota didn't install , cost , use of electricity , no mandate law requiring
  7. fuzzy1
    10,170
    Yes it is a step backwards, but because DRLs are not yet mandated in the U.S., I'm uncertain what sort of response you are expecting from the NTSB.
    My 2010 Liftback also lacked DRLs. It was a nice new feature on the 2012 Liftback, advertised only for the Liftback, not 'c' or 'v'. Did you look at the feature list when you purchased it?
    If this bothers you, then just do what I did only my 2010 Prius and 1997 Subaru, and many others did on all pre-2012 Prii versions: turn the headlights on once, and never turn them off. Auto-off will turn them off when the car is shut down, and back on automatically when the car re-started. No additional thought required. Not quite as fuel efficient as true DRLs, but provides the same safety function. Case closed.
    Did you perform due diligence by looking at the feature list when you purchased it? DRL is not mandated, no disclosure of its absence is necessary. The new 2014 Subaru I brought home two days ago (old one had to be retired, spouse can't stand to not have one in winter) very clearly calls out its presence on the Monroney Sticker.
  8. rdgrimes
    1,740
    446
    New Mexico, USA
    2018 Prius Prime
    the high beams are not LED, only the low beams.
  9. xliderider
    7,869
    3,116
    Honolulu, HI
    Running the high beams at 30% for DRLs use approximately 22w each, probably less than the LED lowbeams use.
    In addition, along with the LED lowbeams, the parking lights and rear marker lights would be illuminated.
    Even if the OP had the same LED DRLs that are on the hatchback, there are 4 high power LEDs per DRL cluster. I'm not sure what wattage each LED uses, but the Audi LEDs are 7w each, I believe. That would put each DRL cluster at 28w of power consumption.
    SCH-I535
  10. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Just a comment, while technically not DRLs, if you just turn the headlights on and never turn them off, your car will always be lit up.
    If you turn off the delay, the headlights go out as soon as you open the drivers door.
  11. Offline
    Offline Active Member
    639
    231
    Lenexa, Kansas
    I went through the same thing with Toyota after we bought our "v" in 2012 - letters to and phone calls with Toyota corporate customer service. I ended up converting the turn signals to DRL: WebElectric DRL-2P installation into 2012 Prius v | PriusChat
    Others on this forum have done the same thing including at least one Canadian that used the DRL-2P kit to satisfy the Canadian DRL requirement when importing a U.S. specification car into Canada.
  12. schinia
    schinia Member
    162
    25
    cape carteret,nc
    believe me, one reason toyota didn't install DRL'S was not to conserve the electrical power draw. then leaves the only reason--PROFIT.
  13. fuzzy1
    10,170
    Considering the fine tuning they had to do to get the 2010 model to achieve a 50 MPG EPA label, rather than having to round down to 49 MPG, I wouldn't be surprised that the DRLs were left out at that time to help achieve the 50 MPG marketing target.
    That possible reason doesn't apply to leaving it off the 'v' and 'c' when it was added to the Liftback in 2012.
  14. xliderider
    7,869
    3,116
    Honolulu, HI
    Effect of DRLs on mpg is negligible. I've been running 50% highbeam DRLs (approximately 55w total) for a year now and you can see from my Fuelly.com widgets in my signature that I'm getting better than 50 mpg. About 60% daytime driving. Most of the mileage is freeway too.
    SCH-I535
  15. fuzzy1
    10,170
    ... as was Prius's margin for getting an EPA MPG label of 50, instead of 49, on the 2010.
  16. Stevevee
    Stevevee Active Member
    821
    224
    Vermont
    I've not once thought about my new v not having DRL's. I wish it had auto on headlights though, which I think is a bigger safety issue for those that forget.
  17. uropip
    uropip Member
    138
    38
    S.E. MASS
    2013 Prius Plug-in
    "Omg my new car doesn't have an option its not sposed to and I wasnt charged for!?!" The humanity! Who should I complain to?
    Seriously? Come on now
    GT-N8013 ? 4
  18. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    I was more bemused by wanting headlights that turn on when you are apparently too busy to notice it got dark, instead of the headlights it has, which are always on, no matter how bright it is. Just leave them on forever, it is not hard.
  19. nwprius
    nwprius Member
    227
    35
    Lacey, Washington
    I do not like DRL's as installed in the U.S. and Canada,(I live in both countries), because the headlight DRL's are on but with 'NO' taillights. I was driving in fog today and many cars were displaying DRL's and no tail lights. DANGEROUS !!! The Prius headlights will do a better job with tail lights on and will go off when you shut down the car and open the drivers door. Much, much, safer.
  20. Stevevee
    821
    224
    Vermont
    I am more bemused by those that need headlights on to see things that move in the daylight ;)
