Drop in mileage in Mid-west winters
Discussion in 'Gen 3 Prius Fuel Economy' started by alokeprasad, Nov 19, 2010.
  1. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    Heh, you should consider a Leaf when they become available in your area, you could drive for two months on one charge!:p
  2. Snake
    Snake New Member
    89
    I was expecting closer to 48, but one of my biggest issues is that I only work 2 miles from home so I am probably not going to see much higher... but I didn't expect 40-41. I got most of my information on mileage from this forum, actually. :cool: However, it seems some people get really high and some people get really low.
  3. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Winter has a dramatic effect on MPG with the
    Prius more than any other vehicle I have owned
    since 1966.
    In summer its easy to get a calculated 53-58 MPG,
    but summer reality is mid 40's to low 40's when temps
    dip below 40 degrees with wet and standing water
    on the roadway.
    Also here in Oregon Winter last 8-9 months, with rain and
    temps in the 40's, even in May.
    Oregon is one of the "Special States" that has 10%
    Ethanol gas ALL YEAR LONG, isn't that nice.
    al
  4. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Your short 2 mile drive is the culprit. All cars get poor mileage w/short drives.
    If it's cold enough outside, grille blocking might help a bit.
    If your expectation was at least based in part on EPA estimates, please read http://priuschat.com/forums/other-c...uth-about-epa-city-highway-mpg-estimates.html. The shortest segments starting w/a cold engine both have 11 simulated miles of distance and are each 31.2 minutes long. That's besides the fact that they drive on a dyno, not a real road nor do they measure actual fuel consumption.
  5. Snake
    Snake New Member
    89
    My expectation was based mostly on what I read here before I purchased, sometimes seeing 50-55 MPG; such as some posts in this thread. That being said I figured it was my commute.
    Where I live it is generally between 70-90 degrees, this winter is just particularly cold (Southern California, LA area). I am interested in Grill Blocking though, but I am afraid of damaging the engine. Any good threads or links I could have to read up on it?
  6. tonyrenier
    tonyrenier I grew up, but it's still red!
    362
    44
    Green Bay, WI
    Sounds about right to me. Beside reformulated gas, using the heater/defroster is a killer (cools ICE, runs more often). I try to use them as little as possible. Also, with my scangauge I can see that it takes "forever" for the engine to reach optimal operating temp even with lower grill blocked.
  7. tonyrenier
    362
    44
    Green Bay, WI
    Yup. Don't use te heater/defroster too much. Dress warm.
  8. TonyPSchaefer
    14,816
    2,499
    66
    Far-North Chicagoland
    Here's my mileage chart over the last six years in Chicagoland. The correlation between temperature and tank mileage is - how do we say - statistically significant.
  9. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    Most (if not all) of those reporting 50 - 55 mpg don't have 2 mile commutes.
    What was the make, model and year of your previous car and what mileage did you get w/the same conditions and commute?
  10. Snake
    Snake New Member
    89
    I realized that before, that was probably my biggest factor. Still better than most cars.
    My previous vehicle can't be considered because it was a motorcycle. I was getting 45 consistently.
  11. Erikon
    819
    105
    Rochester, NY
    I too have a very short commute, less than four miles each way and max posted speeds of 45mph. In summer I typically average between 55 and 60 mpg, running full lower block. When temps drop to 60's or less, full top block as well! Never came close to overheating! Winter drops that average by 10 mpg's! I just had an EBH installed, will see how that improves things and let ya know!
  12. rebenson
    rebenson Member
    364
    43
    Suburb of Chicago
    Going into first winter with Prius.. Also had some changes to my routine with some 1 mile commutes (hey it's tough walking to the train station in dark AND rain)...
    this last tank was 1st to drop and just barely did 50MPG!
    Should be interesting to see how low it goes!
  13. Snake
    Snake New Member
    89
    55 to 60!? Holy crap! Do you mean you block the lower grill? Why does that make a difference?
  14. Daddy Dave
    Daddy Dave Member
    94
    39
    Sheridan, WY
    Sheesh! You're getting 10 mpg better than I'm getting. I've had my 2010 Prius 11 weeks and have 8500 miles on it already. My last tank was 36 mpg! Granted, the commute on almost-closed Wyoming I-90 during a winter storm is about as bad as it gets anywhere in the US. If the weather is good I'll get 43-45 mpg (indicated) at 80 mph. Put studded snow tires on a Prius and it'll go anywhere. I'd put a lift kit on it if one was available.
  15. DonJuan1943
    DonJuan1943 Member
    64
    53
    Northern Illinois
    Bought new 2010 Prius in September '10. Mileage was 48-50mpg for a few weeks. As weather got cooler in Northern Illinois, mileage began to drop. City driving, short trips, complete warmup; mileage now down to 33mpg, temperatures in 20'/30's. Haven't taken a longer road trip recently; but I am disappointed in these mileage stastics. Suggestions??
    Appreciate any!!
  16. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Move to Alaska. ;)
    Is the car parked inside or outside? If outside get an EBH. You might also try grill blocking. What is your typical drive like (mileage, etc)?
  17. geeter
    geeter Member
    208
    16
    Chicago
    I have seen some big drops lately, but not as bad as some of you. I went from around 54 mpg in the warmer months (calculated) to 49-50 thus far in the cold. My last road trip to Southern Ontario netted me about 46MPG over 800 miles.
    I believe the drop seems more significant due to the high MPG the Prius gets. A 10% drop in a 18 MPG SUV is just a couple MPG. In the Prius it could be 5-6 MPG.
    Plus, we expect great mileage so when it is below EPA estimates, it is harder to swallow.
  18. DavidA
    2,344
    1,820
    Chicago western burbs
    That is to be expected. My last car/truck might have done less than 10mpg in the same conditions, so low/mid 30's is actually real good in short drive cold weather. My gas indicator is down 6 pips (of 10) and shows only 189 miles for the current tank. That's about as bad as it will get in Chicago winters. A longer trip every now and then to excercise those batteries is all it takes to reassure you that it can achieve much better mileage.
  19. Peakbagr
    Peakbagr New Member
    33
    Capital Dist
    Searched for what an EBH is and couldn't locate. Can someone explain what it his and how it works?
    Edit: Sorry, found it on Google. How handy do you need to install?
    Thanks
  20. jayrider
    jayrider Member
    163
    17
    southwest illinois
    My mpg has dropped from low to mid 50's to 45 mpg. I'm focusing all my anxiety and anger on that development. As long as I don't think about what a money pit this prius has turned out to be, I'm doing just fine ,thank you. [ Emoticon with one eye winking]
