drop in mpg- not sure why
Discussion in 'Prius c Fuel Economy' started by blue-skys, Jun 14, 2014.
  1. blue-skys
    blue-skys Junior Member
    Tempe, Arizona
    When i first got my 2012 C back in April for the couple of tanks I was getting 54 then 56 mpg. then I started to see a decline. Now I'm getting between 50 and 52 mpg. I have not changed my driving style at all. Any idea as to why the constant decrease?
    52,848
    air conditioning?
  3. blue-skys
    Tempe, Arizona
    I've always used my A/C
  4. Mendel Leisk
    42,343
    Have you checked tire pressures?
    And just curious: it's used? How many miles?
  5. blue-skys
    Tempe, Arizona
    Bought it used with 27k miles. Tire psi all set to 48
  6. Easy Rider
    Easy Rider Active Member
    982
    210
    N. Central Florida
    But it likely wasn't working NEARLY as hard in April as it is now.
    And the hot dry summer air itself cuts down the engine efficiency just a tad.
    You didn't by any chance change the place you normally buy gas did you ??
  7. blue-skys
    Tempe, Arizona
    No, always use the same station. Maybe I'm just being a little paranoid.
  8. Easy Rider
    982
    210
    N. Central Florida
    YIKES. Didn't notice that before.
    If that is 48 "cold", I don't think that is a good idea in a place like you live.
    Have you ever checked the pressure say at 5 PM after being out in the sun all day ??
    Pressure T'HAT high can't be good for tread wear or traction.
    And another thought:
    If your mileage continues to decline, you might want to get the 12 V battery tested.
    A weak battery can cause all kinds of strange things.
  9. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Maybe your brakes are dragging? You can raise the wheels and see if they turn freely.
    SCH-I535
  10. Spock
    Spock Junior Member
    72
    34
    Pasadena, Ca
    2014 Prius c
    for someone driving with AC constantly 50-52 sounds about right. That's almost right on the factory listed numbers. I wouldn't panic unless it dropped to the mid-low 40s, then just take it in early. I'm willing to be you just drove it a bit more moderately early on as most people do with new cars.
  11. fuzzy1
    10,706
    Fuel economy complaints/queries? Please copy, paste & answer these questions, esp. if you're new
    All those warmup factors ought to be rolled into the needed safety margins used for setting the sidewall max pressure label. If that label says 51 psi, he ought to be OK.
    Why not?
    minkus likes this.
  12. Easy Rider
    982
    210
    N. Central Florida
    Do I really want to reply to this.......??
    I probably shouldn't since it looks like you have been on here for 5 years and should know the answer already.
    GROSS over-inflation, in this case ~13 pounds over the recommendation which is 37% over, often causes the center of the tread to wear faster than the edges.......or depending on the alignment, one side faster than the other.
    In addition to that, it makes the tires pretty much rock hard, the tread and sidewalls doesn't flex like they should and it's hard on the suspension and more prone to damage on a hard hit (like a BAD pothole).
    If they were set at 48 in the morning when the temp was say 60 F and then the afternoon temp goes up to maybe 100 F.........the resulting pressure after driving a bit could be around 58.
    It is a matter of opinion if that is really bad or not......and maybe how bad.
    It is also a matter of conjecture whether or not going more than +5 really helps that much anyway.
    They make those recommendations for good reasons; influenced by consideration for comfort, wear and safety.
    I don't deviate THAT much.
    Your opinion might be different.
  13. bisco
    52,848
    a/c is not a constant drain, it is going to use more juice in june than it did in april.
  14. engerysaver
    engerysaver Real Senior Member
    426
    133
    Tyler, Texas ; USA
    HOTTER temps outside; using A/C all the time; getting 50 to 52 MPG; sounds normal to me!!:)
  15. JC91006
    16,936
    8,647
    I can't say any of my cars average over 50mpg, with or without ac
    SM-N900P ?
  16. mahout
    mahout Active Member
    655
    116
    NC
    My guess is combination of A/C and sklowly drop in gas energy as the refineries gear up fotr volume over energy contect. See if it rises next fall.
