Dropped an engine in my 07 prius
Discussion in 'Gen 2 Prius Technical Discussion' started by Letha, Dec 3, 2014.
  1. Letha
    Letha New Member
    26
    Thanks i need that as i seem to keep a rain cloud on me at all times lol
  2. CrazyLee
    CrazyLee Member
    153
    24
    Muskegon, MI USA
    I have a 2004 Prius and I replace the spark plugs with Bosch Iridium.
    I got them from O'Reiley's for $9.00 each.
    I have gotten good results on the fuel mileage.
    Be sure to practice good hypermileing.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,837
    Clearwater, Florida
    I would change the trans fluid and the Invert coolant.
    Trans because it was exposed to alot of dirt with the engine swap as the inner cv joints have to be pulled out of the diff. Fluid should be changed again.
    And the Inverter fluid as that will give you a good boost in your mileage.
    Make sure tire pressure is 42f & 40r.
    Might be real cold where you live don't know as you didn't fill out your locale.
    Then baseline the car. Find a nice straight flat hiway for about 5 miles. Get the car up to 55 mph's and put the cruise control on. Turn off ac or heat. After 3-5 miles the mfd should show at least 50 mpg's.
    I would change the trans fluid and the Inverter fluid. Both are easy.
    The trans becasue
  4. edthefox5
    10,096
    4,837
    Clearwater, Florida
    Bosch makes a horrible spark plug.
  5. cmoore50
    cmoore50 Junior Member
    Nothern IL
    It usually takes the car's ECU awhile to relearn your driving habits after the 12v battery has been disconnected for over 1/2 hour. How many miles have you driven since the replacement engine was installed? I wouldn't worry about anything, especially since you don't have any trouble codes. The winter blend of gasoline doesn't help with mpg's this time of year either. Congrats on the new engine.
  6. Letha
    Letha New Member
    26
    We replaced all the fluids etc i have driven it at least 500 miles... And yes it is cold here... I am in W.v... Todays highs 37 ...
  7. dolj
    dolj Senior Member
    8,631
    4,385
    Wellington, New Zealand
    As others have said, I don't think you need to worry about anything at this stage.
    Wait until you have used another couple of tanks and work out your MPG by dividing the miles travelled on each tank by the gas put in. If it is still in the low 30's rather than higher (late 40's+), then maybe you can look into it further.
    All the best.
  8. bisco
    52,681
    how many miles on her?
  9. Letha
    Letha New Member
    26
    now a little over 60,000 as that is what the engine had on it ...
  10. bisco
    52,681
    right, but how about the rest of the car? there are a lot more things that affect mpg's besides the engine.
  11. Letha
    Letha New Member
    26
    200,000 and the muffler has been replaced the axels the brakes... All the shocks .. Filters.. And fluids.. Etc... I bought it and overhauled it cause i love my priuses this is my second ...
  12. Data Daedalus
    Data Daedalus Senior Member
    1,025
    1,185
    Wembley, London
    Any change in your mpg? When it's cold, the engines on Prii tend to run a lot more often than when the weather is warm. If you have the heating on full blast, that will definitely affect the mpg. Also, the colder it is, and the shorter the journeys, the lesser the mpg count. You more than likely know this already. Of course, it could just be the ECU busy recalibrating itself, what with the new engine transplant. Remember to factor a brief stop - and wait for the engine to cut out once the vehicle has warmed up when just starting out from cold. Apparently, this aids the Prius in running in a more economic manner - as they say, in S4 mode, or something.
  13. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    Gurl, what I would DO to live in a place that I could complain 37 degrees is "cold" :LOL::LOL:. Seriously, when its in the 30's here, I wear my light jacket instead of my winter coat, thick enough for an Eskimo..ha
    It's been anywhere from -5 to 10 degrees here and I'm somehow managing 45mpg. I don't know how but I.m thanking the Prius deity every day for it!! Lol
  14. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    When are you going to retire and move to Florida? :)
  15. PriusGuy32
    1,417
    514
    In 30 years and/or when you win the lottery and invite me down to Florida to help you spend all that juicy money....errr I mean live. :D
    Aaron Vitolins likes this.
  16. Cory151
    Cory151 Member
    102
    27
    Las Vegas
    What caused the other engines demise? How many miles were on it. Where did you get the replacement engine? Did it come with the transaxle?
