Drove a leaf today
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by benalexe, Jan 1, 2013.
  1. John H
    John H Senior Member
    2,208
    558
    not really, I figure I was causing to much backlash on PC advertising 200+mpg instead of MPGe.
    best testimony is $1.76/100 miles for fueling, gas and electric.
  2. John H
    2,208
    558
    sure, let's compare our last 10,000 miles .
  3. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    just yankin yer tail:LOL: :ROFLMAO:
  4. John H
    2,208
    558
    that's usbseawolf2000's job....I'm sure he will chime in here in a second and make claims about electric is bad for ghg emssions and that you can't buy renewable energy.
  5. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    it is?!?!?!?!?!?:eek: :confused:
  6. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    I'd give my Eye Teeth for a GM Solar Tree next to my parking spot.:whistle:
  7. exbauer
    exbauer Active Member
    1,185
    101
    Washington
    I test drove one in my quest for my PIP. It does have some really good pick up, and all being silent. When you floor the PIP it will kick into the ICE unlink the Leaf...since it doesn't have a ICE. But, I needed the option on doing long drives with out charges. So, PIP it was.
  8. John H
    2,208
    558
    using your signature numbers it looks like you are getting about 80 MPGe
    2211 total miles / 18 gallons + 9.7 gallons equivalent = 79.89
    If you put your kWh into fuelly as partial fillups it will calculate your MPGe for you.
  9. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    wouldn't do any good for me because I pay $15.00 a month whether I charge or not.:cry:
  10. John H
    2,208
    558
    too bad. did you consider a rental for the long drives, or a Volt?
  11. John H
    2,208
    558
    same for me, only $4 though ($25/6 months). I still wanted to track the kWh used to show the full picture.
  12. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    too late foe me to get an accurate picture because I haven't kept any of my KWH readings from the beginning cept for the EV Driving ratio, that's from day 1
  13. John H
    2,208
    558
    just use that. take a look at my fuelly fillups as an example. I just put in the monthly kWh totals, not every individual charge up.
    if you using the in-car kWh you might need to upconvert to get "at the wall" kWh, like the EPA uses for MPGe.
  14. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    duh....yeah, I'm a little slo on the uptake, that's 326 KWH divided by 33.4 KWH per gallon =9.76 gallons equivalent. interesting the equivalent is 27.76 gallons and the fuel saved is 27.3 gallons:rolleyes:
  15. John H
    2,208
    558
    yep. your MPGe in EV mode is like 144 MPGe.
  16. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    hmmmmm, get calculatah out 1404 miles EV divided by 9.7 gallons and violah! 144.74 MPGe. I'm getting smarter n smarter, thank's John!:D
  17. John H
    2,208
    558
    your probably the leader in combined MPGe for PiPs, maybe for EV MPGe as well.
  18. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    check out my new signature:D since it's the first fill up there's no data yet. John, how do I fix this?:confused:
  19. lensovet
    2,614
    496
    Burlington, NJ
    Well I'd be a leader too if all my drives were at 15 mph lol
  20. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    There's still time for you:D Come over to the slo side!:cool:
