DTC codes PA080, P3000 on 2005 Prius 160k replace HV?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by karmakid64, Jan 5, 2019.
  1. karmakid64
    karmakid64 Junior Member
    New Jersey
    I have a 2005 Prius with 160k I live inTampa, FL and the red triangle has come on also the check engine and the exclamation point on the top left corner of the display the codes I got are P0A80, P0130 and P3000
    I had been noticing a big decrease in mileage and also the HV battery would discharge and recharge frequently
    do I need to replace the HV? used? or new? is replacing individual cells a good idea?
    what are my options for replacing the HV if need be? is it even worth it?
    are there ant hybrid shops in Tampa that someone can recommend? Thanks for the help im dont know what to do. :/ IMG_0480.JPG
  2. dolj
    dolj Senior Member
    8,633
    4,385
    Wellington, New Zealand
    M in KC likes this.
  3. JC91006
    16,931
    8,640
    You should check if your inverter pump is working. A battery failure usually has more lights.
    Open the inverter coolant cap and see if there's movement in the fluid when the car is READY. I'm thinking it has failed
