DTC hybird ECU P01C1, P1100 and P0000
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Flying White Dutchman, Mar 9, 2009.
  1. Flying White Dutchman
    4,374
    313
    i can not find P1100
    edit : P1100 = BARO Sensor Circuit
    Now to find P01C1.
  2. Flying White Dutchman
    4,374
    313
  3. bedrock8x
    bedrock8x Senior Member
    1,483
    137
    P01C1 does not exit or it is not a published code.
  4. Flying White Dutchman
    4,374
    313
    i think it got something to do with the MAF sensor.
    airflow and air temp
    or the fact that outside air is low but the radiator temp is high.
    this was also the first time the radiator fan spinned.
    it happend after a grill block where i needed to take parts off becaue outside temp was raising and ICE and inverter etc etc getting to close to save temp.
  5. Bob64
    1,540
    92
    Virginia
    how did you pull those codes?
  6. bedrock8x
    1,483
    137
    If you think it has to do with MAP sensor, the code likely be P0101. You may misread the 0 with a C.
  7. Flying White Dutchman
    4,374
    313
    i pulled the code's with canview
  8. Patrick Wong
    18,200
    6,474
    Sounds like your measurement device is reporting bogus codes. Have you disconnected the 12V battery negative terminal for a few minutes to clear ECU memory, and see whether the codes return?
  9. Flying White Dutchman
    4,374
    313
    no misreading here.
    look at picture.
  10. Patrick Wong
    18,200
    6,474
    None of those codes are valid Prius codes. Does your car have a real problem or was this just induced by your use of grill blocking?
    - If the latter, then just clear the codes and don't worry.
    - If your car has a real problem then you'll need a better device to retrieve the DTC.
  11. astrand
    astrand PHEV Guru
    33
    Linköping, Sweden
    My CAN-view reports P0131, B1100, and P01C1. Will clear and see if they return.
  12. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    All Data can be frustrating to use, and some of the text is hard to read, but I could find no reference whatsoever to P01c1, nothing for B1100, or P0131. I used to have a 2004 Prius, but those codes don't seem to exist
    Perhaps somebody with a subscription to Toyota Information System can help
  13. Flying White Dutchman
    4,374
    313
    if you google a bit you get
    B1100 - Airbag sensor assembly malfunction
    P0131 - Oxygen Sensor DTC 02 Sensor Circuit Low Voltage (Bank I Sensor I)
  14. ragman
    ragman New Member
    25
    Chichester, NH
    I just logged on to my TIS and looked and it really is not a valid code. I even expanded the search to cover all Priii and nothing for that code anywhere on the toyota site.
    Software glitch on the scantool?
    By the way, since I moved to New Hampshire to be with my Dad, I have this 2 year subscription to TIS that I never use except to fix my own Prius. I would be delighted to look up stuff if anyone needs!
  15. Flying White Dutchman
    4,374
    313
    ragman we now have 6 codes in this topic
    what one where you referring to?
    P01C1, P1100, P0000 P01c1, B1100, or P0131
  16. ragman
    ragman New Member
    25
    Chichester, NH
    Doh! sorry, the P01c1, and P01C1. P0000 also doesn't pop up, although that could just be the scantool saying that for whatever test it found no codes.
    B1100 is the airbag code as stated earlier, P0131 is the O2 sensor, P1100 is the baro system monitor
  17. Flying White Dutchman
    4,374
    313
    sorry P01c1 is my fualt its just P01C1.. the same
    thats the only one i can not find to date.
    P01C1,??
    P1100, baro system
    P0000 ?? no fault i guess
    B1100 airbag code
    P0131 02 sensor
    P stands for powertrain . so it must be related to that.
  18. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    i was getting odd error codes when one of my spark plug's ignition coils started to fail. eventually that cylinder stopped firing.. but that was about 30k miles later. i had traction control, and brake codes, along with a few other odd ones.
    just a suggestion to look into....
  19. jawshoeaw
    jawshoeaw Junior Member
    67
    Oregon
    I just got the P01C1 and P1100 on CAN-View - the car lost a lot of power (no battery contribution). I tried clearing the code with engine on but they kept coming back. I pulled over, disconnected my BMS+ and restarted - codes went away. When i got home I reconnected BMS+ and codes did not come back (yet). I've been testing out the BMS+ with just the OEM battery so maybe ECU got grumpy about the battery getting out of happy range. Battery voltage was fine though, 230V or so. The BMS+ box or possible the CAN-View got jolted going over a bump - not sure.
    Note: I'm using Norm's BMS+ with the CAN-View which allows use of more than one battery.
  20. Flying White Dutchman
    4,374
    313
    a ok...
    only with the oem battery pack
    that is not a smart thing to do
    you take the oem pack down to 195 volts ( did you also have the AC on? ) and then when you want to accelerate the oem pack drops its voltage to low.
