DTC- P0304- Prius V 2016
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Garry20-20, Aug 2, 2020.
  1. Garry20-20
    Garry20-20 Junior Member
    35
    2016 Prius v wagon
    Luxury
    Hi Guys,
    As I said, the dealership had told me to replace IM and Egr gasket....today i brought my car back home after I paying him for the diagnostics.
    Dealership in my area had no IM gasket. I decided to clean IM , Throttle body myself and keep the old IM gasket till I get the new one.
    I followed NutsandBolts video for IM cleaning.
    The problem is - Before it was vibration while driving But Now my car is ratting while park. I am scared and need your help.
    IM- After removing EGR Pipe, I removed IM. There was mild oil (1-2 teaspoon ) at the base (where Throttle body sits) of IM. There was a lot of carbon near the IM holes and near Fuel Injectors. Fuel injectors seemed fine.
    I first cleaned IM with Carbon cleaner and brake fluid. During this clean, I removed Manifold position sensor.
    Later, I decided to go to car wash and give good pressure wash with mild soap to IM. I used bristle brush to clean it.
    I pressure washed from the hole where the EGR pipe joins IM and the water was coming out from the small holes. After wash, I assembled everything but with old IM gasket.
    I also cleaned Throttle body with TB cleaner.
    After assembling everything, when I start the car, It rattled. I switched it off quickly.
    I rechecked Throttle body, disassemble it and overturned it, it was dirty with old oil (back side of the throttle plate). I cleaned that side, assembled every thing and start the car....same loud rattle.
    I than recalled that I kept the FUEL VAPOR FEED HOSE OPEN- ( I did not pinch it).
    I Have various questions in mind:-
    Is rattling due to the :-
    1 Old head gasket?
    2 Moisture in the IM (Incomplete dry) ?
    3 Open fuel vapor feed hose pipe ?
    4 use of too much carbon cleaner?
    5 Issue with Manifold absolute pressure sensor?
    I need your advice . Thanks
  2. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Did you ever try swapping the old plugs - all 4 - back?
    Also - "and keep the old IM gasket till I get the new one." Wonder if that could be the problem - a leak there?
    I'd be surprised if it was Head Gasket - leave that till last.
  3. Garry20-20
    35
    2016 Prius v wagon
    Luxury
    Hi Alanclarkeau,
    Thanks for your reply.
    Yes, I swapped the old Plugs, but still same issue. (before taking it to the Dealer).
    Also, when I rechecked the MAP sensor, there was mild oil (side facing the IM) but not clogged. I did clean it with rag BUT not MAF sensor cleanrer.
    Regarding head gasket-- My engine coolant level is normal, no white smoke from the tailpipe.
    What do you think about the new rattle after cleaning IM and TB?
    Thanks
    alanclarkeau likes this.
  4. Garry20-20
    35
    2016 Prius v wagon
    Luxury
    Update:-
    I rechecked all my connections (electric and hoses) after cleaning IM, TB, MAP sensor. I kept my old IM gasket (Even now I got new gasket and PCV valve from the dealership).
    After first start up, it rattled...I did not switched off the engine ...and after 1-1.5 minutes of running ... The smooth sound of engine running came back.
    I drove the car about 15-20 mins and there was no jerk and vibration..WOW.
    I think that jerk was due to mild moisture due to IM cleaning at car wash or due to carbon cleaning.
    Now there is no any code.
    Reflection:- If I reflect back, small hole on IM (of #4 cylinder) was blocked with carbon (that runs from EGR pipe to #4 Cylinder), that was forced open with pressure wash. I think, that blockage was the reason for #4 cylinder misfire.
    It also means that my plugs/ Ignitions coils/Fuel injectors were fine. P_20200805_133807.jpg P_20200805_133819.jpg P_20200805_144032.jpg P_20200805_153558.jpg P_20200805_163541.jpg
    Overall, the car runs very smooth now.
    I am very thankful to all the members of this wonderful Platform who spent their precious time and share their suggestions.
    Thank you again.
    Now, as I received new IM gasket and PCV valve (from dealership)..will update after changing them.
    Raytheeagle likes this.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,269
    15,528
    Bay Area, California
    2019 Prius Prime
    Glad it's sorted and back running well:).
    Chock another one up for the pressure washer(y).
    Prodigyplace likes this.
