DTL VS instrument lights
Discussion in 'Gen 3 Prius Technical Discussion' started by Seymour1, May 13, 2025.
  1. Seymour1
    Seymour1 Member
    272
    36
    In Virginia, it is a law that if the windshield wipers are on, the headlights must be on, even in the deytime. When I switch on the headlights in the daytime, the instruments are hard to read although the rheostat is turned to maximum brightness. Is there a way to increase the range of the instruments dimmer control? (maybe there is a resistor in series with the rheostat?) A schematic of the dimmer circuit might help me if you have one.
  2. Buzzhead
    Buzzhead Non-Interference w/ devel of pre-Warp civs
    151
    59
    Chelmsford, MA
    Have you rolled it up past the detent? When you do that the instrument panel lights go full on just like in daytime when the headlights are off.
    bisco and Brian1954 like this.
  3. Seymour1
    Seymour1 Member
    272
    36
    Detent? I just ran out and learned that that is a detent and it does what I need. Maybe I should read the owner's manual. Thanks for the info.
